runco vfc-4400
Krepticor
PostLink    Posted: Sat Jul 14, 2018 5:18 am    Post subject: runco vfc-4400 Reply with quote
does anyone have Anymore info on this line doubler/tripler/quadrupler?
PostLink    Posted: Sat Jul 14, 2018 1:29 pm    Post subject: Reply with quote
More info here: http://www.curtpalme.com/VideoProcessors.shtm#Runco
What are you looking for exactly?
PostLink    Posted: Sat Jul 14, 2018 4:06 pm    Post subject: Reply with quote
I've worked on a few of them back in the day. Not really good units, even 10 years ago, and worthless at this point. Probably about $20K when new though.
PostLink    Posted: Sat Jul 14, 2018 8:58 pm    Post subject: Reply with quote
They definitely had that massive Sam Runco markup on them! Wink
PostLink    Posted: Sat Jul 14, 2018 10:23 pm    Post subject: Reply with quote
BTW, if you need a low cost scaler, look for a used Lumagen or Faroudja. Far better and more reliable than the Runco. A bunch of the Runcos suffered from bad caps, causing low output, color shift, etc.
Krepticor
PostLink    Posted: Sat Jul 14, 2018 11:17 pm    Post subject: Reply with quote
well I found one cheap and wanted a line doubler/quadrupler for converting old rgbs output videogames prior to a scaler, issue is I know the output on most of those is actually 240p
my issue is I do not seem to be getting video from the runco
I dont have my projector setup just yet, so I can't wire it up to that just yet, just testing for functionality at this point
PostLink    Posted: Sun Jul 15, 2018 1:27 pm    Post subject: Reply with quote
A line doubler/quadrupler is a scaler. Simply one with a fixed output resolution. A doubler takes 480i to 480p. A tripler to 720p. A quad to 960p.
More info: http://www.curtpalme.com/CRTPrimer_18.shtm
PostLink    Posted: Sun Jul 15, 2018 3:00 pm    Post subject: Reply with quote
No scaler save perhaps for a Lumagen will convert an RGBS signal to anything. If the Runco has a VGA input, it's simply a passthrough connection from that VGA connector to the 5 BNC outputs.
You should be able to take the RGBS output and connect it directly to your projector RGBHV input. If you use the RGBH inputs, that's equal to RGBS.
PostLink    Posted: Sun Jul 15, 2018 3:54 pm    Post subject: Reply with quote
Why not run 240p on the projector? Scan lines 6 feet high!
nidi
PostLink    Posted: Sat Apr 20, 2019 9:17 am    Post subject: Reply with quote
anything you need to know about retrogame video formats and best processors can be found here:
http://retrogaming.hazard-city.de/
hope that helps
Michael
