haireez
Link Posted: Sat May 26, 2018 1:50 pm Post subject: G70 Arc Flash exhibit on Splitter During Start-up |
Dear all,
Trying to help my Friend G70 issue recently. He mentioned that there will be a small lightning arc flash whenever he try to turn on his G70. This arc flash coming from the HV splitter that are connected to the various tube.
I would appreciate any advise from the expert in this forum.
_________________ 2 White Vision 1
Link Posted: Sat May 26, 2018 10:37 pm Post subject: |
It either needs a new HV splitter or HV leads going to the tubes.
haireez
Link Posted: Sun May 27, 2018 2:25 am Post subject: |
OK. I need to go to his place to check and see this and determine the root cause. He actually has a second set as spare that I can take and do troubleshooting.
BTW, how much is one G70 splitter or hv lead?
Link Posted: Sun May 27, 2018 5:51 pm Post subject: |
I have leads at $10 each. I need a picture of your splitter. I have an HV assembly sitting on the shelf, but I think it's from an older 12XX series. The splitter may be the same though.
haireez
Link Posted: Sun May 27, 2018 7:41 pm Post subject: |
Thanks Curt but I’m on holiday right now and will only be back 2 weeks later. I will check at his place when I’m back from holiday. Thank you.
haireez
Link Posted: Sat Jun 09, 2018 6:38 am Post subject: |
Splitter found damaged and found arc coming from there. I have replaced with another spare splitter and now, there is an arc coming from green tube. Not too sure what to do now.
I also realised that when I reinstalled the cables to the splitter, I accidentally installed incorrect sequence. Any issue if I installed cable from HV voltage right in the middle of the splitter? Will it damaged the tubes?
