Radiance 2041 and max bandwidth
Corleone88
PostLink    Posted: Tue Apr 24, 2018 9:44 am    Post subject: Radiance 2041 and max bandwidth Reply with quote
Hello,
The 2041 is supposed to resolve 2160p at 30Hz. So the bandwidth is 3840x2160x30=249MHz. It means the 2041 should resolve 2488x1400p at 72Hz (upscaling 1080p24 input for example). Am I right?
PostLink    Posted: Tue Apr 24, 2018 1:59 pm    Post subject: Re: Radiance 2041 and max bandwidth Reply with quote
That is not true.
Maximum Input Resolution on the 2xxx series is 1080p60
Maximum Out Resolution on the 2xxx series is 1080p60, or 2160p60 in the case of the 2143/2144 only.
No 2xxx series can accept higher than 1080p on inputs. You need a Radiance Pro to do that.
See our comparison table here: http://www.curtpalme.com/Radiance.shtm#FeatureComparison
Corleone88
PostLink    Posted: Tue Apr 24, 2018 7:52 pm    Post subject: Reply with quote
You are right, this is the output not the input.
