UncleWill
Joined: 11 Dec 2012 Posts: 400 Location: WashDC area, ViennaVA
Link Posted: Thu Mar 29, 2018 5:36 pm Post subject: HDTV Antenna |
Having a huge problem configuring my HDTV antenna off a balcony, 3rd floor. One direction it gets more, the other it picks up others but loses others. Jeez!
Not running an amplifier, cable is under 50ft but I have a longer one. How much a difference does an amplifier make with reception? Any recommended amplifiers?
Link Posted: Fri Mar 30, 2018 12:09 am Post subject: Re: HDTV Antenna |
UncleWill wrote: | Having a huge problem configuring my HDTV antenna off a balcony, 3rd floor. One direction it gets more, the other it picks up others but loses others. Jeez!
Not running an amplifier, cable is under 50ft but I have a longer one. How much a difference does an amplifier make with reception? Any recommended amplifiers? |
I have set up dozens of antennas.
First which model antenna is it?
Second how do you have it mounted?
Third what kind of cable are you using? CCS, RG59, RG6, RG6 Quad Shield?
Cable makes a huge difference especialy without an amp. I recommend RG6 copper Quad Shield better than CCS which is Copper Clad Steel.
Lastly; the amp depends. I have had amplifiers here 5 pieces identical where 3 blocked the signal completly and 2 boosted it giving me more channels. It's sort of hit or miss sometimes. One I have used with good sucsess is the RadioShack: Catalog #: 1500473
https://www.radioshack.com/products/radioshack-1-in-4-out-bidirectional-3ghz-cable-tv-amplifier
UncleWill
Link Posted: Sat Mar 31, 2018 5:19 am Post subject: |
Which way does the balcony face? Is the other building in line with the TV broadcast towers? If so that makes it a little more difficult to get all the channels ( obviously ).
The antenna looks OK, I've never had hands on with that exact antenna but it looks allot like the small Yagi's I've installed. They do benefit from an amp and RG6 Quad Shield. Keep the run from the antenna to the amp short. Say just long enough to make it inside; 5-6 feet. Then your longer run from the amp to the TV.
Go for the copper RG6 QS stuff on eBay. Decent deal.
The odd thing when there is a building in the way is you can sometimes get a better signal by bouncing off the other building.
UncleWill
Link Posted: Sun Apr 01, 2018 10:32 pm Post subject: |
Balcony looks like this. The easiest way to mount seems to be on the lattice.
You can see the other complex directly across.
257.36 KB |
5394 Time(s) |
UncleWill
Pic #2
204.39 KB |
5392 Time(s) |
UncleWill
Link Posted: Sun Apr 01, 2018 10:39 pm Post subject: |
This is the antenna range from where we are. The balcony faces south or southeast.
350.34 KB |
5390 Time(s) |
UncleWill
Link Posted: Thu Apr 05, 2018 12:46 am Post subject: |
Feeling silly now. Just used a short cabled indoor antenna. Seems to pick up most of the local channels (NBC, FOX, ABC) that I really wanted. It has a power port to amplify this signal. If I can find it, this may be the easiest solution. Durp durp.
Link Posted: Thu Apr 05, 2018 1:38 am Post subject: |
Antenna reception is a fun experimental thing. I tried 20-30 antennas back in 2008-2009 to see what was best for where I am. Some of the small ones are pretty decent. What's the small model you picked up?
Looks like all the stations except one are north of you. Too bad, BUT again, try bouncing the signal off the building infront of you. Experiment.
UncleWill
Link Posted: Sat Apr 21, 2018 12:27 pm Post subject: |
How long should the RG6 QS coaxial cable ideally be? I know were talking the shorter the better here. Was thinking about 50ft to be sure.
Link Posted: Sat Apr 21, 2018 6:09 pm Post subject: |
UncleWill wrote: | How long should the RG6 QS coaxial cable ideally be? I know were talking the shorter the better here. Was thinking about 50ft to be sure. |
Yep, keep it short, amp close to the antenna and use quality, quad shield co-ax.
UncleWill
Link Posted: Sun May 20, 2018 3:54 pm Post subject: |
So I bought the 50ft quad shielded cable. Set it up going to the outside balcony. Slightly better reception (I thought). The one channel I cannot which I cannot get is Fox 5 or its affiliates.
In a moment of curiosity, I pulled out my DTV box from the digital switcherover - the kind you hook up to really old TVs. Wow! The little guy picked up almost all of the channels. My guess is that since my HDTV receiver is older, it might not be strong enough to pick everything up?? Strange cause it is a much nicer unit, outputs RGBHV, etc.
Link Posted: Mon May 21, 2018 2:27 am Post subject: |
There are many different generations of tuners. They all tune ATSC but some are way better than others.
I picked up a Memorex 19" TV that gets more channels than my $200 Samsung ATSC tuner from 2009 which has HDMI component etc...
Bostom
Link Posted: Wed Nov 21, 2018 1:14 pm Post subject: |
I went through a lot of this years ago and my setup's still working great.
Started at tvfool (don't see a mention of it here so thought I'd add it in).
I went with a nice roof-mount antenna but a lot of the attic ones are excellent. From there, ran the cable in to 3 silicondust homeruns (so 6 ota tuners) which are plugged into my switch. Took the cable lead coming into the house and connected it to an hdhomerunprime (the cablecard is something like $3/month), also plugged into the switch. The homeruns are all ip-addressable tuners so everything in the house with a computer, xbox, etc attached to it gets all OTA and cable channels.
As long as you have SOME signal, an amplifier can help a lot. The other thing that helps is to limit the number of splits. Going with a homerun might be a good option for you as you won't split your line but still have access to 2 tuners. If you are going to split the line, do it as far down the line as possible.
Link Posted: Fri Nov 23, 2018 4:49 am Post subject: |
I had a Silicon Dust tuner. Never did get it to play with winblows. Got it working in Linux for a bit.
