Corleone88
Link Posted: Thu Feb 22, 2018 8:21 pm Post subject: Scan fail light on with BG 1209s |
Hello,
After trying to go inside the "Install" menu, I had a black screen and I noticed that the scan fail light on the G2 board was on (all the green ones are on too). I can adjust geometry and convergence but not with my external signal (1080p72).I did it with 15KHz internal signal.
I did not notice any other red light on the other boards.
What is wrong?
Thanks for your help
Corleone88
Link Posted: Fri Feb 23, 2018 5:26 pm Post subject: |
Swapping with the 2 video boards (with the white wires soldered), fix the problem, but I had an issue with these boards (green with vertical lines).
HaydnG90
Link Posted: Fri Feb 23, 2018 8:58 pm Post subject: |
Get new ones from Curt and see if the green line disappears. You'll have peace of mind that they are tested and known to be good.
