SHARP LC-80LE844U
PostLink    Posted: Thu Jan 18, 2018 3:02 am    Post subject: SHARP LC-80LE844U Reply with quote
Anyone know how to do a factory reset on a SHARP LC-80LE844U ??
larryp
PostLink    Posted: Tue Feb 06, 2018 9:12 pm    Post subject: Reply with quote
On-Screen Menu Reset
1
Start up your television and press the "Menu" button on your remote control.
2
Navigate through the menu options with the left and right arrow keys until you find the "Setup" sub-menu.
3
Select "Reset" and press the "Enter" button. If you've set an access code--referred to as a "Secret Number"--for parental controls, enter it with the number pad on the remote control and press "Enter" again.
4
Highlight "Yes" using the left or right arrow key and press "Enter."
5
Select "Yes" again when prompted that the television will restart and press "Enter." The TV will then display "Now Initializing" and the power will shut off. The television will automatically turn back on, restored to factory defaults.
Hard Reset
1
Unplug the television.
2
Press and hold the "Channel Down" and "Input" buttons on the panel.
3
Plug the television back in while holding down these buttons. You may need the assistance of another person to accomplish this step.
4
Keep holding the buttons until the television powers back on. If it doesn't work, unplug the television and try again--sometimes this process doesn't work on the first try.
5
Use the remote to navigate the "Service Mode" menu and select "Factory Reset" from the menu. Click "Enter" and the television will begin initializing and shut down. It will then power back on, set to factory defaults.
Tips
check
It's best if you use the on-screen method first before using the hard reset to set the television to service mode, then reset from that menu.
check
These steps are often the first that Sharp technical support will ask you to work through when trying to diagnose or potentially solve the television's iss
PostLink    Posted: Wed Feb 07, 2018 2:07 am    Post subject: Reply with quote
Thanks! I passed it along.
