sukwoto
Link Posted: Fri Dec 01, 2017 1:59 am Post subject: no picture at green tube |
Hello,
I have problem at my green tube (Barco 1209 Graphics), no picture but has an orange glow at the tube.
I was switch the neck board but still can't working.
Pls advice
Thank you very much
Regards
Sukwoto
dvh99
Link Posted: Sat Dec 02, 2017 12:36 am Post subject: |
probably broken tube
Link Posted: Sat Dec 02, 2017 1:06 am Post subject: |
Not if there is a glow at the base of the tubes. That's just incorrect advice.
As I mentioned before, you now have to get in there with a meter and measure voltages to see where you are missing a signal from.
sukwoto
Link Posted: Sat Dec 02, 2017 2:53 am Post subject: |
Curt Palme wrote: | Not if there is a glow at the base of the tubes. That's just incorrect advice.
As I mentioned before, you now have to get in there with a meter and measure voltages to see where you are missing a signal from. |
Would you please to explain " 6 volt supply coming from the main power supply (SMPS) that goes to each 762292 board to supply the filament voltage"...which one cable should be checking
Thank you
sukwoto
Link Posted: Sat Dec 02, 2017 3:42 am Post subject: |
sukwoto wrote: | Curt Palme wrote: | Not if there is a glow at the base of the tubes. That's just incorrect advice.
Thank you |
303.57 KB |
3423 Time(s) |
Link Posted: Wed Dec 06, 2017 5:15 am Post subject: |
sukwoto wrote: | sukwoto wrote: | Curt Palme wrote: | Not if there is a glow at the base of the tubes. That's just incorrect advice.
Thank you |
That cable would be for video not a cable for voltages. The cables that carry voltage are located at the other connector that runs from the mother board (Frame) to that RGB amp. They are usually yellow wires on Barco projectors (except 9 series). I don't have a manual for that projector so I can't say which wire it would be.
Having said the above (and I don't know what other discussions you have had) its also possible that the issue is related to the video circuit so do you have any spares to swap out including a SMPS a RGB input and RGB driver boards?
sukwoto
Link Posted: Wed Dec 06, 2017 11:35 am Post subject: |
I was try to swap the RGB board, but stil not working.
The LED at that board just one (right) is On
My SMPS just replace a view month ago from Curt, I think I still Ok
Pls advice
redfox001
Link Posted: Wed Dec 06, 2017 12:59 pm Post subject: |
Check for bend pins. Sometimes when you insert the neckboard one pin does not go into one hole and it bends.
sukwoto
Link Posted: Thu Dec 07, 2017 2:42 pm Post subject: |
Yes, I check the pin and I pull tight the neck board into back tube.
It's working
Thank you for advice
redfox001
Link Posted: Wed Dec 13, 2017 2:15 pm Post subject: |
sukwoto wrote: | Yes, I check the pin and I pull tight the neck board into back tube.
It's working
Thank you for advice |
Good!!!
