ziani67
Link Posted: Wed Oct 11, 2017 4:03 pm Post subject: valeur barco 909 actuellement |
hello, what is present value barco 909 in good condition
Thank you
Corleone88
Link Posted: Thu Oct 12, 2017 8:07 am Post subject: |
Bonjour,
Je te conseille d'écrire ton message en anglais si tu veux des réponses .
Sinon pour répondre à ta question, je dirais entre 1300 et 1800 euros en fonction de l'usure des tubes.
Link Posted: Thu Oct 12, 2017 1:25 pm Post subject: |
Define 'good'. It's all about the condition of the tubes, and that the software is higher than 2.0. If the tubes show wear, it's worth very little at this point.
ziani67
Link Posted: Thu Oct 12, 2017 3:10 pm Post subject: |
Thank you for your answers
Tubes in very good condition 9.5 / 10 software I do not know
cordially
ziani67
cordially
Link Posted: Thu Oct 12, 2017 3:51 pm Post subject: |
I'd have to get you to post a screen shot of the green tube face with the lens off. No offense, but EVERYONE says their tubes are in perfect shape, but the high end 9" sets are so sharp, that a bit of tube wear at 500 hours is almost to be expected, which then lessens the value of the CRT.
ziani67
Link Posted: Thu Oct 12, 2017 6:37 pm Post subject: |
I have not yet the opportunity to make pictures, but as soon as possible I will post
Thank you
Link Posted: Thu Oct 12, 2017 9:05 pm Post subject: |
ziani67 wrote: | I have not yet the opportunity to make pictures, but as soon as possible I will post
Thank you |
Then the question arises whether you ask the price because you want to buy it for yourself or you'd like to sell it?
ziani67
Link Posted: Fri Oct 13, 2017 6:05 am Post subject: |
yes it 's for a purchase
jask
Link Posted: Sat Oct 14, 2017 3:52 am Post subject: |
where are you located? (just hoping you are in Kamloops... that would save shipping costs... )
ziani67
Link Posted: Sat Oct 14, 2017 7:07 am Post subject: |
yes right by side, barely 18h of plane
ziani67
Link Posted: Fri Nov 03, 2017 8:29 am Post subject: |
Hello, I need to know the noise level of the barco sp909fr compare to the Sony vph g90 example au au 1292 or barco 808
Thank you
Link Posted: Fri Nov 03, 2017 11:15 am Post subject: |
The Barco Cine 9 is one of the most quiet CRT projectors because of its modified firmware, the 909 is more noisy because of the standard firmware. By SP909 do you mean split pack? If so the split pack is most similar to the normal 909, but because of the nature of the split pack design you are able to put the electronics in a different room to save on noise.
ziani67
Link Posted: Fri Nov 03, 2017 1:31 pm Post subject: |
thank you for your answer, my configuration does not separate the two, that's why I want to know the device that comes closest to noise level
I know bd701 bg808 sony 1292 sony g70 sony g90
thank you
