hjhjr
Link Posted: Tue May 30, 2017 11:05 pm Post subject: crt tubes P19LP02 |
I have a a red & blue tube from a marquee 9500LC .They appear to be P19LPV02 from base wiring and the modified VNB. I also have a red, green & blue tubes which I bought from Niktec. I had a problem with the projector and spotted the green CRT and never used the projector. Is there any interest in the CRTs they show no sign of wear. Any one interested in these tubes and what are they worth. I think they require the 40KV high voltage power supply. I have the 3 modified VNBs.
79.11 KB |
8893 Time(s) |
137.32 KB |
8893 Time(s) |
123.8 KB |
8893 Time(s) |
101.86 KB |
8893 Time(s) |
115.85 KB |
8893 Time(s) |
Link Posted: Tue May 30, 2017 11:20 pm Post subject: |
That's basically an LCP tube with the same pinout as Sony tubes. It'll work the same as an LCP once the neck board is modified correctly.
They're made by Lexel. Lexel usually makes first rate tubes. They should be good to go.
Link Posted: Wed May 31, 2017 4:37 am Post subject: |
They look like Thomas tubes particularly based on the fact they have a Sony pin out.
Are there any other numbers on the tubes?
Link Posted: Wed May 31, 2017 10:53 am Post subject: |
I have one that is identical to that one, when I get a chance I'll dig it out and check the label information on it.
It's a Sony pinout tube in a Panasonic envelope format.
I was thinking Lexel but upon second thought, it MIGHT be a Thomas tube. I know that it's always been easier to get custom tubes
made by Thomas than by anybody else.
hjhjr
Link Posted: Wed May 31, 2017 2:19 pm Post subject: |
There are no numbers or text on the tube.
Link Posted: Wed May 31, 2017 2:37 pm Post subject: |
Warning
Those are hacked-together early VDC rebuilds with home-made electron guns and dreadful focus. Worthless.
Link Posted: Wed May 31, 2017 3:56 pm Post subject: |
No, Tim, THIS tube type is a special type built to order for L3 Communications to provide a Panasonic format tube that is plug and play compatible with FSI Skylight projectors which used Sony tubes.
VDC had nothing to do with them.
Note the distinctive funnel shaped component in the gun assembly. VDC rebuilds never had that.
But VDC DID use the same brown dag coating which contributes to the similarity.
Link Posted: Wed May 31, 2017 10:00 pm Post subject: |
Say CM
I tried to help this guy two years ago. And I launched Novatron into the Panny rebuilds. They DID use a gun like that, and these tubes are likely From Novatron.
Link Posted: Wed May 31, 2017 11:09 pm Post subject: |
But it's the Sony pinout that's the kicker. Have you ever heard of VDC making a rebuild with a Sony pinout?
I know for a fact that you can get Sony pinout, Panasonic format tubes from Thomas and Lexel.
Link Posted: Thu Jun 01, 2017 12:02 am Post subject: |
Say CM
These were done Custom for this one guy as he had a very old M9000 with 40kv
hjhjr
Link Posted: Wed Jun 07, 2017 3:50 pm Post subject: CRT Faces |
CRT faces. Could only display crosshatch pattern due to the crts are hooked to a projector with a 34KV HV power supply.
252.74 KB |
8691 Time(s) |
106 KB |
8691 Time(s) |
155.47 KB |
8691 Time(s) |
193.26 KB |
8699 Time(s) |
Download |
Filename: |
green 1.jpg |
271.59 KB |
Downloaded: |
423 Time(s) |
Download |
Filename: |
red.jpg |
271.59 KB |
Downloaded: |
444 Time(s) |
hjhjr
Link Posted: Thu Jul 05, 2018 4:33 pm Post subject: tubes for sale |
Is any one interested in buying these tubes before I trash them?
