Link Posted: Sat May 13, 2017 7:23 pm Post subject: FS: Rare cable connectors for Sony G70 neck boards |
I have a small quantity of these hard to find cable connectors that are found on the two black RF cables
that run to each Sony G70 neck board.
These are new, unused, and just what a few of you need to restore your G70 to reliable operation.
You know those connectors are easily pulled off and they can't be reused.
Just restrip the wire, make sure the center strands are twisted tightly together, tin them a little bit to hold them together,
slip thie new connector on, and crimp or solder the center pin. Squeeze the tabs on each side of the barrel to lock it to the cable.
Price is $3.00 each plus shipping.
68.78 KB |
2764 Time(s) |
