No image with moome card on Barco Cine 8
napos
PostLink    Posted: Fri May 12, 2017 11:10 pm    Post subject: No image with moome card on Barco Cine 8 Reply with quote
My friend George just received a brand new barco moome card.
We followed the installation instructions step by step, but there is no image no matter what we tried. Do you guys have any suggestions we can try before returning it to Moome for an exchange with another card?
Thanking you in advance,
Nicholas
Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
PostLink    Posted: Sat May 13, 2017 2:42 pm    Post subject: Reply with quote
You need to post how you have it connected, what you have it connected to, and what resolution you have set on the source unit. You're not giving anyone enough information to work with. Smile
napos
PostLink    Posted: Sat May 13, 2017 2:57 pm    Post subject: Reply with quote
The connection is: Oppo 93 to Lumagen Radiance XS to Moome card. output set at 1080p60.
We also tried connecting a laptop directly with no success.
I have asked George to try connecting the Oppo directly to the moome card set at 1080p60. I will let you know if he got any picture on the Barco.
The exact same setup worked fine with the Moome Ext v3 box, which recently malfunctioned after 3 years of operating fine. That is why George opted for the internal card, to replace the external box.
gregstv
PostLink    Posted: Sat May 13, 2017 8:58 pm    Post subject: Reply with quote
Make sure you select port 3. Then select the input on the moome remote. The top input is 1 on the moome remote.
napos
PostLink    Posted: Sat May 13, 2017 9:04 pm    Post subject: Reply with quote
Thank you Greg. We already tried the remote as well as the button on the port 3 moome dongle to switch inputs. No image at all. The cine 8 will switch to port 3 via the barco remote, but still no image.
gregstv
PostLink    Posted: Sat May 13, 2017 9:55 pm    Post subject: Reply with quote
Are the leds on on the
PostLink    Posted: Sat May 13, 2017 10:15 pm    Post subject: Reply with quote
Are you sure the external Moome card failed? If the RGB switcher or possibly the quad decoder board failed, that would kill all incoming video.
napos
PostLink    Posted: Sat May 13, 2017 10:23 pm    Post subject: Reply with quote
The external moome box just has all its leds flash red when you plug it in, without anything connected to it. It just keeps flashing all the time with or without an hdmi connected. I doubt anything is wrong with the cine 8. The external box just started misbehaving before even turning on the barco all of a sudden. I will ask George to verify that he can get an analog signal displayed through port 5.
gregstv
PostLink    Posted: Sat May 13, 2017 10:27 pm    Post subject: Reply with quote
There are less on the internal moome.
PostLink    Posted: Sun May 14, 2017 5:09 am    Post subject: Reply with quote
Does the internal Barco Moome card strip HDCP?
gregstv
PostLink    Posted: Sun May 14, 2017 5:57 am    Post subject: Reply with quote
That should of said LEDS on the moome
napos
PostLink    Posted: Mon May 15, 2017 2:47 pm    Post subject: Reply with quote
Thank you all for all the suggestions. The moome card seems to operating, but it doesn't seem to be sending a signal to the video board. I have also e-mailed Moome and am waiting to hear back from him.
ElTopo
PostLink    Posted: Thu Jul 27, 2017 12:11 pm    Post subject: Reply with quote
Any update on this ?
I have a Cine9 but no picture from all of the hdmi ports at present.
Barco Cine 9 the one and only
ElTopo
PostLink    Posted: Thu Jul 27, 2017 2:03 pm    Post subject: Reply with quote
Update: Got a picture now with the Oppo BDP 93 from the Card. The old Philips Player i have first connected seems to be buggy.
Tests to follow
