mookee
Link Posted: Sun May 07, 2017 8:02 pm Post subject: Electrohome Marquee 9500LC |
hi
i have thechance of purchasing a Electrohome Marquee 9500LC in good condition. only thing is that the guy says it looses a little bit of convergence when it is turned off..
i know thats difficult , but its all the info i have. what problem can that be, can i fix it or how much will it probably cost me to fix it..?
dont know if i should buy it
please tell me what you think#
thanks, best christoph
Link Posted: Sun May 07, 2017 8:12 pm Post subject: |
Most likely the battery is depleted on the control module, that would be an easy fix. However with that old machines it is not unusual to have the rubber bellows sweating glycol which is not very nice. You'd better check the machine in person...
mookee
Link Posted: Sun May 07, 2017 8:29 pm Post subject: |
hi gjaky
thanks. that sounds fixable
gjaky wrote: | However with that old machines it is not unusual to have the rubber bellows sweating glycol which is not very nice. You'd better check the machine in person... |
you mean on the tubes, or the cappacitators, or what exactly??
thx
best, christoph
mookee
Link Posted: Mon May 08, 2017 12:24 am Post subject: |
If the bellows are sweating they really need to be replaced. It's not a bad job but it's a solid evening's work to do all three and do them right. Curt can provide new bellows. I make the very strong recommendation of ditching the old style metal clamping ring and black oxide bellows screws (18 of them per tube assembly) and getting Curt to provide you with the newer style plastic clamping rings, and obtaining replacement stainless steel screws and washers. (18 each per tube assembly)
Link Posted: Mon May 08, 2017 4:41 pm Post subject: Re: Electrohome Marquee 9500LC |
mookee wrote: | hi
i have the chance of purchasing a Electrohome Marquee 9500LC in good condition. only thing is that the guy says it looses a little bit of convergence when it is turned off.. | if the control board battery is bad you would lose a lot more than a little convergence, You would lose all saved parameters.
more likely the recall memory (channel) is locked , or the the boards need to be rebuilt.
Check the channel by pushing recall on remote when the machine is on, if you see a small key symbol pop up it's locked. Unlock in Service menu, channel set-up
Link Posted: Tue May 09, 2017 3:31 am Post subject: |
A little bit of convergence drift from "cold" to "warmed up" is to be expected. But it should be a matter of only a few line widths of the convergence grid. If it's more than that then the unit probably could use recapping on certain boards.
greg9518lc
Link Posted: Tue May 09, 2017 9:15 pm Post subject: |
Cm It would be nice to see some shots of your projector to
Show the sharpness you are talking about screen size and lenses
used. I recall you saying you have a high end Nikon so should be
simple enough with the tools and skills you posses. I am sure other members
would like to see this as well. I would be happy to post mine as well and am sure
others would follow.
Link Posted: Tue May 09, 2017 11:48 pm Post subject: |
I will state that I don't think the projector in question is any sharper than any other well set up Marquee of the same type CAN be.
The two that I'm spending time with at the moment are both stock but slightly different models. While I have MP modded
VIM and neck boards for both, they're not currently installed in a unit.
One is a 9501LC with a 1997 chassis, upgrade to an Ultra, and the other is a 2008 factory built Ultra with the newer 21778 neck cards. Both have LUG tubes in new condition.
Both are all stock (stock configuration, I can't say that they haven't had something swapped in them) but I've gone above and beyond to optimize everything I can. I believe that doing the same thing can help a lot of people to drag more sharpness out of their own stock machines.
As for screen shots, I've been meaning to get around to doing that.
