Link Posted: Sat Apr 01, 2017 9:36 pm Post subject: Need a simple way to adjust a signal over HDMI. Front porch |
My source to projector is as direct and simple as it can be HDMI cable from Blu-Ray player to HDMI input on my Marquee Ultra.
I like things to be simple and direct.
But the problem is, I have problems with raster ringing when using short retrace in the projector settings, and if I use
long retrace then I get other problems that are worse.
I need to be able to adjust the timings in the HDMI signal to eliminate the ringing, assuming that that will work, and I am asking for recommendations for processors that can do this, without costing me a lot of money along the way.
gregstv
Link Posted: Sun Apr 02, 2017 9:16 am Post subject: |
I use a DVDO VP50. Picked it up for a couple of hundred bucks. Works great as long as you don't want to go higher than 1080p@60. I use mine also for 817p@72. I have compared 1080p@60 from the player to the projector and then through the VP50. Could not really see any difference. They should be real cheap over your way now. Its also has a good selection of test patterns.
