spankedmonkey
Link Posted: Fri Mar 24, 2017 3:36 am Post subject: Sony G70 FullHd V2 1.3 Green Screen Help |
I have a G70 with Moome FullHD V2 1.3 card feeding multiple sources through a Denon AVP A1HDCI. Sources are HD-DVD, Denon 4010 Blu Ray, DirecTV HD, D-VHS, and PS4. I've had no problem until recently when signal is fed from the PS4 and D-VHS the picture is green. I've tried feeding these two sources through the same inputs on the AVP that works fine with HD-DVD and Denon Blu Ray Player but the picture is still green. Switched between RGB and YCBR in the AVP settings but no fix. Any advice on this one?
_________________ Knowing is not enough you must apply. Willing is not enough you must do. -Bruce Lee
spankedmonkey
Link Posted: Thu Dec 07, 2017 1:03 pm Post subject: |
So I meant to follow up with this some time ago. After searching I found that pressing the number 4 button on the Moome Card remote corrects the signal input problem. Loving my G70 VR, feeding all sources mentioned problem free.
Joined: 08 Mar 2006 Posts: 26038 Location: Toronto, Ontario, Canada
Link Posted: Thu Dec 07, 2017 4:36 pm Post subject: |
The magic number is 4. Thanks for the update. Does the manual actually tell you what that does?
spankedmonkey
Link Posted: Thu Dec 07, 2017 11:39 pm Post subject: |
Literally no mention of it in the manual. In fact just functions of input, gamma, and output range 0-255/16-235 listed via the remote. Kind of dug up this info. after a lengthy search.
