Link Posted: Sun Feb 05, 2017 5:13 am Post subject: FS, used G90 P19LQF green tube, 50 dollars plus shipping |
This is kind of a test to see if anybody wants some lightly used tubes.
Here's a worn, but not heavily worn, green P19LQF I just removed from a G90 and replaced with a minty fresh green P19LUG.
I have made every effort to make the face picture fairly represent how the tube actually looks to the naked eye.
On my monitor, this picture looks like the tube looks.
The wear pattern is even and close to full frame in size. It is doubtful that your raster would cross over the edge of the wear pattern.
The P19LQF is essentially the same thing as a P19LUG tube. It is compatible with any projector that uses P19 LQF, LPB, LUG, or LCP series tubes. G2 is on pin 6 on this tube.
50 dollars plus shipping takes it.
Anode lead not included. You are buying a bare tube as seen. I'll leave the lead shield belt around it.
87.67 KB |
2768 Time(s) |
102.53 KB |
2768 Time(s) |
