3D theater problem
SubaruB4RSK
PostLink    Posted: Wed Dec 21, 2016 7:19 pm    Post subject: 3D theater problem Reply with quote
I'm trying to get it to work with my Mitsubishi EW270u but the 3D option is grayed out still the projector only support frame sequence
PostLink    Posted: Wed Dec 21, 2016 7:30 pm    Post subject: Reply with quote
What source are you using?
What resolution is the source set to?
What resolutions does your projector support?
Are you able to see a picture at all on your projector if you hook up the source directly to the projector? Your projector seems to support only 1280x800 max so make sure you can see a picture before you put the 3DTheater between the source and the projector.
Your projector has to support 720p60 or 720p120. If it doesn't, the 3DTheater will not work.
It doesn't matter what the projector supports in terms of frame sequence or similar as the 3DTheater is there to convert the 3D signal into one that a non-3D projector can understand.
Make sure to check out our setup guide here too:
http://www.curtpalme.com/3DTheatre.shtm
SubaruB4RSK
PostLink    Posted: Wed Dec 21, 2016 8:00 pm    Post subject: Reply with quote
using my PS3 and the projector supports the following (narrowed it down) 1024x768 60/120 hz 1280x800 60/120 hz
Btw I can see the image but it's not having the projector think it had the correct mode for me to turn on 3d
PostLink    Posted: Wed Dec 21, 2016 8:31 pm    Post subject: Reply with quote
How are the 3DTheater dip switches set?
SubaruB4RSK
PostLink    Posted: Wed Dec 21, 2016 9:00 pm    Post subject: Reply with quote
first one is up.
PostLink    Posted: Wed Dec 21, 2016 9:32 pm    Post subject: Reply with quote
Have you tried it down? IF you don't have a picture with it up, the display doesn't support 120Hz. Turn the 3DTheater off and on.
Complete details in the setup guide: http://www.curtpalme.com/docs/3D%20NOW%20Setup%20and%20Fine%20Tuning%20Guide.pdf
SubaruB4RSK
PostLink    Posted: Wed Dec 21, 2016 10:15 pm    Post subject: Reply with quote
I tried both ways I have picture on both but one makes like a 3D image and the other just shifts frames every 2 seconds. Projector not seeing it was 3D signal
PostLink    Posted: Thu Dec 22, 2016 12:59 am    Post subject: Reply with quote
It sounds like that display does not work correctly with the 3D-Theater.
SubaruB4RSK
PostLink    Posted: Thu Dec 22, 2016 1:55 am    Post subject: Reply with quote
im trying to figure out why.. I wonder if I get the emitter would it work? I can get the theater to show a 3D like image but I rather just use the dlp link.
PostLink    Posted: Thu Dec 22, 2016 2:38 am    Post subject: Reply with quote
The 3D-Theatre does support any 120hz 3D Ready DLP-Link projector by brands like Optoma, Benq, Viewsonic, etc. It could be that your projector does not, in which case you'd need to use 60/120hz 3D Glasses with emitter.
SubaruB4RSK
PostLink    Posted: Thu Dec 22, 2016 5:00 pm    Post subject: Reply with quote
where can I get the RF glasses and the emitter?
PostLink    Posted: Thu Dec 22, 2016 8:01 pm    Post subject: Reply with quote
See here:
http://www.curtpalme.com/RFGlasses.shtm
These have been tested with the 3D-Theater.
