Plasma PIONEER-PDP-5016HD help
silv55
PostLink    Posted: Thu Dec 08, 2016 9:44 pm    Post subject: Plasma PIONEER-PDP-5016HD help Reply with quote
Hi guys i have here a Plasma PIONEER-PDP-5016HD- that was connected to a Xfinity cable box and sudden pic and sound went off but still has display screen and menu,i did not opened it yet but i suspect main board!,do you guys know any history on this model#? i have the Service manual,any tips on where to start! thanks in advance.
https://www.manualslib.com/download/...dp-5016hd.html
http://www.ebay.com/itm/PIONEER-PDP-...8AAOSwqYBWoHty
PostLink    Posted: Fri Dec 09, 2016 5:21 am    Post subject: Reply with quote
IF all menus work fine, then you're most lilkely correct, the input board or main CPU board is bad. Best bet is to take a chance and buy another used one on eBay, but assuming that this is a few years old, and considering Pioneer is long out of the TV market, I'd scrap it and get something else.
PostLink    Posted: Fri Dec 09, 2016 6:45 am    Post subject: Reply with quote
try all inputs one by one and see if any give you a picture.
silv55
PostLink    Posted: Fri Dec 09, 2016 7:55 pm    Post subject: Reply with quote
Thanks guys;Today i had to clean the boards cause they were full of dust and durt , i used a Vacum cleaner ,
now power supply won't turn on,i only have the 125v at Fuse 1 and no volts at all, it's dead now with only steady red light that i can switch off and on on the main switch.
i reed somewhere about a light sensor Pioneer uses the trap switch ,can you guys elaborate on this,thanks
