JVC DLA X3/DLA-RS40 Flashing amber and red lights.
incova
PostLink    Posted: Wed Oct 26, 2016 10:49 pm    Post subject: JVC DLA X3/DLA-RS40 Flashing amber and red lights. Reply with quote
Hi Guys,
I have had a crt pj (Ampro 4600 HD) for years but I no longer have any time to change stuff around or fix it as its getting old in the tooth so I thought I would try out a JVC projector.
I managed to snag a x3 which I think is the RS40 for about 370 usd with emitter 4 glasses remote and a bulb with 35 hours on it, the caveat being its was not working and has flashing red and amber lights. The seller thought a update could take care of this. I went to the jvc site downloaded the update and now I have got the xp mode patch for windows as I have a 64 bit version on on the pc I am going to use to try and flash the firmware. The seller stated that the pj's test menus and lens adjustments worked fine but I am not sure of how to access this to test that, any advice would be great.
Right now any advice on the pj would be good just to see if I can get it up and running.
Much appreciated.
The more I learn
the less I know.
PostLink    Posted: Thu Oct 27, 2016 1:18 am    Post subject: Reply with quote
Hmm, so you swapped a CRT that needed work for a digital that needed work. Your sentiment of not having time to work on the Ampro now makes no sense. Very Happy
I'd like to help, but know nothing about the JVCs, sorry!
PostLink    Posted: Thu Oct 27, 2016 1:38 am    Post subject: Re: JVC DLA X3/DLA-RS40 Flashing amber and red lights. Reply with quote
I'm afraid that doesn't make much sense. If the projector doesn't work at all, a software update won't 'fix' it.
If all it took was a quick software update the seller would have done this himself in 2 minutes and sold the projector for considerably more money. If the projector doesn't work at all, you pretty much need to send it in for repair, same as all digitals.
You can try the update if you like, I just don't think it'll make any difference. I don't think the fact that you're running 64 bit is an issue - the instructions to update are here:
http://pro.jvc.com/pro/attributes/PRESENT/soft/rs40_firmware_manual_EN.pdf
And they state that you need "A Standard PC running Windows XPô or Later with a USB Port.".
To pull up test menus and other adjustments, hit the "MENU" button on the remote.
PostLink    Posted: Thu Oct 27, 2016 2:22 am    Post subject: Reply with quote
Let me know if you want to part out the 4600HD. I call dibs on the tubes and magnetics, maybe the lenses, too, if the tubes
are in good enough shape, that is!
incova
PostLink    Posted: Thu Oct 27, 2016 11:28 am    Post subject: Hey guys Reply with quote
Hi Curt,
I knew someone would say that, I did say it to myself! The main issue with my ampro was the surges and power supply problems to be honest, I have had a good run from it and may try to get her running again but it has been difficult. Most of my ampro parts I got from you but you are quite a distance away and I am in the UK. I got it originally as it came with a spare set of tubes and at around $50 was a good deal, never regretted it even after shipping.
Kal I did try to use the menu button on the JVC nothing worked, the seller stated it did work and you could see the setup menu. I pointed the remote at the back front up down and the remote comes on but no signal seems to get through, I have heard of this issue with jvc,s but as the seller had the screen up I did not think it had this issue. From the screen shot he took and what he said the lens and the bulb seemed to be working. As for the update you are probably right but there are quite a few people out there who are not at all like our little group and will not even try and get their pj working themselves.
Hi Cm, my previous green tube had arcing I switched it out with another I had. Tubes are in very good condition in the ampro I put in green and red c elements and the lenses are HD 10f. I may try and get it working as I stated, everythings set up so we will see.
Most likely I seem to have been sold a brick but thanks for the suggestion Kal I just thought I may need an input so thats the problem.
The more I learn
the less I know.
PostLink    Posted: Thu Oct 27, 2016 11:55 am    Post subject: Reply with quote
That indication could mean it needs lamp reset or there's a problem with the Lamp Power Supply
Red Flashing - During cool down
Orange Flashing - lamp has exceeded 2900 hours.
Does the lamp come on at all?
PostLink    Posted: Thu Oct 27, 2016 12:24 pm    Post subject: Reply with quote
FWIW, the owner's manual is here:
http://pro.jvc.com/prof/attributes/inst_man.jsp?model_id=MDL102022&feature_id=11
PostLink    Posted: Thu Oct 27, 2016 12:27 pm    Post subject: Re: Hey guys Reply with quote
incova wrote:
...but as the seller had the screen up I did not think it had this issue. From the screen shot he took and what he said the lens and the bulb seemed to be working.
Did you see the projector running in person?
incova
PostLink    Posted: Thu Oct 27, 2016 12:46 pm    Post subject: Hello! Reply with quote
Hi Mike,
The seller stated
"projector went into a mode with flashing red and amber lights with no image. All the test menus and lens adjustments worked fine. I believe from the Internet that a firmware update corrects this.
Extremely good condition. Recent new bulb showing 37 Hours only use."
I can now say thats true the projector came on I pressed menu on the pj and hours on the bulb are 37.
I then hooked up a dvd player and it locked up with no image.
The lens cover is open I cannot put it off and the standby light is a solid red, the lamp light is amber the warning light is red.
The lamp light and warning light seem to be flashing twice with the standby light on red.
The more I learn
the less I know.
PostLink    Posted: Thu Oct 27, 2016 1:09 pm    Post subject: Reply with quote
I've not really repaired many smaller digitals and no JVC's at all. But one thing that's common with the technology (lamp), and that is when the LEDs flash or become an indicator that something is wrong. The problem is usually always the one of the Lamp, Lamp Power Supply or Fan.
I've serviced a many work site with the smaller digital projector, where the about was the problem. One thing you should always have around is a lamp. That is to never throw away an old lamp that has been replaced with a new lamp, because you will need it when problems like this show up. So all of the sites had used or old lamps for test purposes. The old lamp is needed because of the sensitivity of the lamp power supplies. Not all lamps work properly with the lamp power supplies, and even with a low hour lamp, the power supply can still reject it later.
The first thing I would suggest is to replace the lamp. It has that low hour rate that usually goes with this problem. If the lamp checks good after replacement, make sure the fan works and that the speed it turns seems reasonable.
incova
PostLink    Posted: Thu Oct 27, 2016 7:53 pm    Post subject: Running Pj Reply with quote
Hi Kal, no it was on the other side of the UK so I took a plunge and went for it, I never saw it running.
The more I learn
the less I know.
