HDMI cable?
silv55
PostLink    Posted: Sun May 01, 2016 8:49 pm    Post subject: HDMI cable? Reply with quote
Hi guys: are the Hdmi cables High Speed?
http://amzn.to/1TEd2yl
(Link modified to support our forum at no extra cost to you - we thank you!)
PostLink    Posted: Sun May 01, 2016 10:28 pm    Post subject: Reply with quote
What's your application, equipment and what resolution are you running?
silv55
PostLink    Posted: Sun May 01, 2016 11:19 pm    Post subject: Reply with quote
Thanks AnalogRocks: i want to connect Roku4 1080P to this switch;
http://amzn.to/1rLsgJm
And then running 30 feet hdmi cable to Lcd TV 720P.
http://amzn.to/21osH8f
And another 6 Feet HDMI cable to a LED tv 1080P
PostLink    Posted: Mon May 02, 2016 2:52 am    Post subject: Reply with quote
Why do you need high speed cables if you are only running 720p?
silv55
PostLink    Posted: Mon May 02, 2016 3:17 pm    Post subject: Reply with quote
I don't know much about HDMI cables but what i know and learned so far,
i connected this cable:see link billow between Roku 4 and 1x2 a-b switch.
http://amzn.to/1rrDvpE
and i had bad connectivity between my Roku and A-B push button 1x2 switch and 30 feet high speed cable to lcd tv 720P,
now i had this cable see link billow on other tv setup and connected it and now all good.
http://amzn.to/24jP7Na
PostLink    Posted: Tue May 03, 2016 5:20 am    Post subject: Reply with quote
The first cables are the same as the ones I see at the dollar store. Super cheap, OK in a pinch but not for long runs. Second one's look pretty and have higher spec's than the first. Funny thing about digital cables. Either they work or they don't. Seems you have the solution.
silv55
PostLink    Posted: Thu May 05, 2016 1:08 am    Post subject: Reply with quote
Yes it's working great now both the switch and both tvs
