sony vph cards IFB hdmi
johnyfazer
PostLink    Posted: Thu Mar 17, 2016 10:03 am    Post subject: sony vph cards IFB hdmi Reply with quote
Hello. I removed my Sony G70. It was my card IFB HDMI Sony VPH. If anyone needs Ifb hdmi please write priv. Real photo. I'll send a package of Polish Greetings.
 Filesize:  47.39 KB
 Viewed:  4557 Time(s)
Ebri
PostLink    Posted: Thu Mar 17, 2016 2:59 pm    Post subject: Reply with quote
Do you reckon this unit to work in a vph1252q?
PostLink    Posted: Thu Mar 17, 2016 5:51 pm    Post subject: Reply with quote
It will, I have one in my 1252. Just be aware you will need to set your source to 1080i or 720p when using HDMI as this card will tell the source it's 1080p compatible.
johnyfazer
PostLink    Posted: Thu Mar 17, 2016 6:17 pm    Post subject: Reply with quote
I have yet efficient projector Sony VPH 1272. card provides a very good quality of 1080p on this item.
Link to the specifications:
http://www.curtpalme.com/SONY_IFB-HD.shtm
johnyfazer
PostLink    Posted: Thu Mar 17, 2016 6:49 pm    Post subject: Reply with quote
whether there is a possibility that modding my card to work in the 808s Barco ?? Is it possible?
robnec
PostLink    Posted: Fri Mar 25, 2016 6:56 pm    Post subject: Reply with quote
hello. is it still available? thank you.
PostLink    Posted: Sat Mar 26, 2016 10:51 am    Post subject: Reply with quote
Yes, most likely. You need to supply the board with its specific supply voltages, but the output is still RGBHV, you just have to mate the IFB card connector with the projector.
The MOD: VNB-DB
johnyfazer
PostLink    Posted: Sat Mar 26, 2016 1:27 pm    Post subject: Reply with quote
Hello. I brag about Smile. My Barco retro graphics 808s LC- element C", lenses sony g70 .... made in poland Smile
 Filesize:  51.65 KB
 Viewed:  4295 Time(s)
PostLink    Posted: Sat Mar 26, 2016 2:53 pm    Post subject: Reply with quote
Looks great! My only critique is that I hope you have some cooling in that setup, as the Yamaha receiver, and all equipment above it, including the projector will cook themselves quickly if you don't.
johnyfazer
PostLink    Posted: Sat Mar 26, 2016 3:02 pm    Post subject: Reply with quote
I thought so. I am an amateur electronics. Physically connecting contacts Barco vs moome I can do. I have a meter, but I do not know how to measure the voltage in order to enable the association pin Barco vs moome Sad
johnyfazer
PostLink    Posted: Sat Mar 26, 2016 3:18 pm    Post subject: Reply with quote
Thanks for your feedback. I did it yesterday. You're right, I will think about additional cooling.
johnyfazer
PostLink    Posted: Mon Nov 04, 2019 4:20 pm    Post subject: Reply with quote
Hi . I have the opportunity to buy Barco cine 8 onyx. I have a further converted retrographhics 808s with lc sony vph g70 lenses. I am very pleased with this. Will barco cine 8 onyx be even better? Does anyone know what lamps are inserted into cine 8 onyx?
johnyfazer
PostLink    Posted: Mon Nov 04, 2019 4:27 pm    Post subject: Reply with quote
onyx = USD 130, good lamps in ranking 9
PostLink    Posted: Mon Nov 04, 2019 5:55 pm    Post subject: Reply with quote
I don't think the Onyx will be any better, but at $130 USD, give it a try. Not sure of what tubes are in it, sorry! Most likely P16 tubes, but I think those are also in the 808 retro unit as well.
johnyfazer
PostLink    Posted: Mon Nov 04, 2019 6:22 pm    Post subject: Reply with quote
OK thanks. In retro I have pt18 probably panasonic
PostLink    Posted: Tue Nov 05, 2019 6:25 am    Post subject: Reply with quote
Unfortunately the Onyx will have poorer lens (HD-215) than the G70, they don't even have corner focus adjustments. Otherwise the Onyx is mostly the same as the RG808s, if nothing else you'll have some spare parts.
The MOD: VNB-DB
johnyfazer
PostLink    Posted: Thu Nov 14, 2019 4:02 pm    Post subject: Reply with quote
Hi. I found another projector in Poland: "Barco Retro Block Reality 908". The projector has 500 hours of lighting, the lamps are perfect. It looks the same as RetroGraphics 808s, of course without the rear projection housing. Can anyone write something about this projector? Lack of information. I don't know yet which lenses are mounted on. Will this generally be better than my 1980s retrograms? I have another set of lenses and "c" elements from Sony VPH G70 that I could wear up to 908.
PostLink    Posted: Fri Nov 15, 2019 3:34 am    Post subject: Reply with quote
Thats not anything like 808s. That unit is a 909 with 8inch tubes instead of the 9inch tubes. In terms of lenses and games someone else might have that info.
johnyfazer
PostLink    Posted: Fri Nov 15, 2019 7:23 am    Post subject: Reply with quote
Yes, I just realized that this is a strange device from the link below:
https://www.google.pl/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&ved=2ahUKEwjGj6nv3OvlAhXnwcQBHT7GDvcQjRx6BAgBEAQ&url=https%3A%2F%2Fwww.barco.com%2Fservices%2Fwebsite%2Fzh-CN%2FTdeFiles%2FDownload%3FFileNumber%3DR5994649%26TdeType%3D1%26Revision%3D00%26ShowDownloadPage%3DFalse&psig=AOvVaw1NXgc8P_lSfCXGujBscbQW&ust=1573889657151022
Can a BD 3D source be connected to this? I have no idea about the conditions of 3D projection, I have never been interested. "Baron" lenses will be unusual from the rear projection and will not work well. I wonder if I can exchange them for HD18 and Sony VPH G70 + element "c". I don't know if they will match exactly. Retro 808 fits perfectly to minor modifications. Will the old type of remote control from retro 808s work with "Baron"?
