runco projector
2manytvs
PostLink    Posted: Sat Mar 05, 2016 5:33 pm    Post subject: runco projector Reply with quote
Came across a Runco cp610lt at a thrift for 100 bucks but no remote. It does nothing without remote,
can't verify it works.
Does it seem worth the chance and are remotes easily and resonably obtained.
Thanks 4 any ops.
PostLink    Posted: Sat Mar 05, 2016 5:45 pm    Post subject: Reply with quote
A quick search didn't show me what model projector is under that Runco case. Ge your googling gun going and see if you can find out what projector that was based on then likely the OEM remote will power that up.
Do be ware, in my searching I saw people that had issues with failed color wheels and bad capacitors in that model. So don't spend too much on a remote just in case.
Also does it have an RS-232 port on it? If so you may be able to power it up that way.
2manytvs
PostLink    Posted: Sat Mar 05, 2016 5:54 pm    Post subject: rs 232 Reply with quote
How would I use the rs232, would it need a proprietary program to access unit?
Macht Nichts!
PostLink    Posted: Sat Mar 05, 2016 5:56 pm    Post subject: Re: rs 232 Reply with quote
2manytvs wrote:
There's usually a set of command codes listed in the installers manual. You can generally control a projector from a terminal program by selecting the COM (RS-232 )port and sending the correct string.
See if you can find the manuals for that projector online and find the command codes.
EDIT: forgot to add you usually need an RS-232 cross over cable where RX and TX are wired to each other. Also known as a NULL modem cable.
A strait through cable wont work because the receive RX and the transmit TX would be wired together. That;s like 2 phones trying to communicate with the mics wired together and the ear pieces wired together it won't work.
PostLink    Posted: Sat Mar 05, 2016 6:17 pm    Post subject: Reply with quote
I think this is a set made before Planar bought them. There's very little support for it out there. I've got a VX5 in the same condition, can't find the remote, and the set is useless without it.
2manytvs
PostLink    Posted: Sun Mar 06, 2016 2:06 am    Post subject: Reply with quote
Update:
It was gone when I went back.
Someone either knew what to do or are in for a disappointment.
Thanks for info!
Macht Nichts!
PostLink    Posted: Sun Mar 06, 2016 2:46 am    Post subject: Reply with quote
Whew!! You ARE lucky aren't you? Wink
Jeremy112
PostLink    Posted: Tue Mar 08, 2016 12:10 am    Post subject: Reply with quote
The CP610 is a native 720p DLP HD Projector, probably throws a pretty good image (for $100? Can't really go wrong if it worked!) I have a VX-5000D That also requires the remote, luckily I have it (as clunky and difficult as it likes to be) to operate the PJ
