Marquee 1.3 screen width issue
PostLink    Posted: Thu Feb 18, 2016 1:31 pm    Post subject: Marquee 1.3 screen width issue Reply with quote
I've always had a slight (I mean, slight enough that I never really worried about it) screen width issue with my Moome V1.3 input card in my Marquee.
The image from the card is just a little bit too wide. And I do mean just a little. Not much at all. My screen is 8 feet wide and the image is maybe 2 inches wider at most.
Long or short retrace doesn't fix it. Setting blanking to zero doesn't fix it. Adjusting raster width doesn't fix it,
because a small section of the image is simply not being displayed at all.
I can see the missing area by shifting the image but no combination of settings allows the entire image to be displayed at one time.
Like I said, it's just a little bit. I've lived with it for years and never really cared about it.
But I am curious, has anyone else encountered the same thing and if so, have you found a fix for it?
redfox001
PostLink    Posted: Sun Feb 21, 2016 7:31 am    Post subject: Reply with quote
removed
PostLink    Posted: Sun Feb 21, 2016 5:37 pm    Post subject: Reply with quote
It's a straight path from BDP to Moome card to projector. Of course I've considered source timings but the Sony BDP seems to lack those adjustments.
I can do without your smarmy comments. I formally disinvite you, redfox001, from any participation in any topic I start.
Your comments are not welcome and will henceforth be ignored as if they were never written.
You burned that bridge, bub.
Beeffold
PostLink    Posted: Mon Aug 29, 2016 9:26 am    Post subject: Reply with quote
oh its getting hot in here. but on the other note, i think your Moome V1.3 on your Marquee has a compatibility issue. screen width are most likely always an issue and there is an adjustment somewhere maybe you just didn't notice it yet. but if it doesn't worry you too much, then don't mind it.
PostLink    Posted: Mon Aug 29, 2016 1:20 pm    Post subject: Reply with quote
Digging up an old topic that hasn't been visited in six months?
The answer is that there is a mod that some Marquees need which corrects the issue where you can not by any adjustment actually display both edges of the picture at the same time.
There's a service bulletin about it in the archives on this site.
