Edge blend 2 x Barco 919 tryout
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
redfox001
PostLink    Posted: Mon Nov 02, 2015 1:05 pm    Post subject: Edge blend 2 x Barco 919 tryout Reply with quote
I have some contacts at the local university and last week I got an email that they would clear out their Barco 919 projectors.
In 2010 I stumbled upon 5 Marquee 8500's from them and I told them if they ever would upgrade to digital they should mail me and they did Very Happy
So no way I could let this go and now I got the idea to do a blend with two Barco 919's. They have the semu advanced 2 soft edge blending boards and they have the contrast modulation on the RGB driver. So first thing will be to check out how that works.
Well what can I say of these? They came with the HFQ900 so no curved screen. But there was also a set of HD10-R5M so I could do a curved setup with one to try Cool
As you can see on the pictures the green tube is turned 90 degrees but I also have normal tubes that have a little more wear.
The green have fast phosphor pt22 tubes the blue and the red are LUG tubes with almost no wear. The very light wear on the green is a square. So I am thinking if I do a blend I will be projecting a square again 1/2 x 16/9 = 8/9.
Both Barco's will use half the bandwidth but for the gamma to be linear I need 72 Hz. I know that because the Marquee 8500's also had fast phosphor on green and at 72 Hz I remember they where razor sharp and linear in gamma. So worth a try. No bad point at all here. I might even use them for 3d 120 Hz gaming Cool
I think sooner or later I will have to cut out the tubes. I have some spare LUG LC housings left for that. But I wonder why they where used like this? They came from a cube where 3 where rear projecting and one was above front projecting. What was the advantage in only turning green? Original they had normal greens but from the documentation I saw that they replaced these after little wear around 2009. They have around 750 hours since than.
Some pictures!
Contrast modulation on the RGB driver
Soft edge on the controller. Semu advanced 2.
redfox001
PostLink    Posted: Mon Nov 02, 2015 1:07 pm    Post subject: Reply with quote
So how to proceed? I will try the Barco soft edge and contrast modulation and I know there is software for the pc and for the mac.
PostLink    Posted: Mon Nov 02, 2015 3:00 pm    Post subject: Reply with quote
Rotate the green tube first, otherwise you'll be using very little phosphor. You should be able to rotate the green tube 90 degrees, and still use the video amplifier, but the heat sink will be sitting sideways. that's not really an issue, as the mounting clamp holds it in place.
hansilili
PostLink    Posted: Mon Nov 02, 2015 3:33 pm    Post subject: Reply with quote
You suck!
Looking forward to your fully documented report of the curved blend built.
Cheers
hansilili
tschaeikaei
PostLink    Posted: Mon Nov 02, 2015 8:39 pm    Post subject: Reply with quote
Me too!
And i could think of making some deal with green tubes if you want to.
Regards, Julian
2 Marquee 8500U 2001 P43 | Barco 801s LC | NEC 9PG
redfox001
PostLink    Posted: Mon Nov 02, 2015 10:05 pm    Post subject: Reply with quote
Ok think you are right.
I am also thinking about trying these green tubes. The wear seams to be big enough for a normal 16/9 but for a blend? I guess these where used with a curved screen.
redfox001
PostLink    Posted: Mon Nov 02, 2015 10:09 pm    Post subject: Reply with quote
Me too!
Regards, Julian
Yes that is always possible but first I want to see how these pt22 look.
redfox001
PostLink    Posted: Mon Nov 02, 2015 10:11 pm    Post subject: Reply with quote
hansilili wrote:
You suck!
Cheers
hansilili
No curves. The HFQ900 are for normal projection luckily.
redfox001
PostLink    Posted: Tue Nov 03, 2015 11:47 pm    Post subject: Reply with quote
Think I can put my coffe on this table Very Happy
tschaeikaei
PostLink    Posted: Wed Nov 04, 2015 7:39 pm    Post subject: Reply with quote
Let there be light!
redfox001
PostLink    Posted: Sat Nov 07, 2015 11:12 am    Post subject: Reply with quote
Getting the 90 degrees tube out the housing and into a new house of an old worn tube is not so easy. There are a few scratches in the new house. Guess I can cover them with the new silicon kit I need to use.
This is the new house.
I will get the silicon kit used in aquaria.
It is impossible to just turn the front as the bellow is glued to it.
PostLink    Posted: Sun Nov 08, 2015 8:12 am    Post subject: Reply with quote
Why didnt you just turn the front plate???
PostLink    Posted: Sun Nov 08, 2015 8:36 am    Post subject: Reply with quote
Use black etching paint to cover the scratches before you put silicon on.
Hulio
PostLink    Posted: Sun Nov 08, 2015 11:09 am    Post subject: Reply with quote
You just can't do that Case, without distroying the rubber bellow. It's all one molded piece. Changing the whole LC chamber is the only altenative, i'm affraid.
redfox001
PostLink    Posted: Sun Nov 08, 2015 11:38 am    Post subject: Reply with quote
Something like this? This is available close to me.
http://www.ebay.co.uk/itm/E-Tech-Self-Etch-Primer-ER00112X6-/351424755359?hash=item51d28c369f:g:cBAAAOSw-vlVn~Tv
I remember Franciscus said he just painted the scratches with the silicon. I think that will hold too?
redfox001
PostLink    Posted: Sun Nov 08, 2015 11:58 am    Post subject: Reply with quote
Ok I am exploring possibilities and I am thinking if the blend works than why not try a tripple blend Very Happy
All three work perfect. Needs some work on the green tubes.
Building a huge hushbox and duplicating the fanboards to get these silent seems mandatory.
redfox001
PostLink    Posted: Sun Nov 08, 2015 12:00 pm    Post subject: Reply with quote
Oh wait I have another one but that one needs a focusboard repair.
barclay66
PostLink    Posted: Sun Nov 08, 2015 12:02 pm    Post subject: Reply with quote
That qualifies You for being called a hoarder! Wink
redfox001
PostLink    Posted: Sun Nov 08, 2015 12:53 pm    Post subject: Reply with quote
Lol Very Happy
This is how I got them all 6!
It is a one time thing as they now only have digital left.
This is where they come from. But they where used in a cube close to this. Not on a curved screen.
ElTopo
PostLink    Posted: Sun Nov 08, 2015 8:06 pm    Post subject: Reply with quote
How big will your screen be ?
I hope > 3m in width Mr. Green
Barco Cine 9 the one and only
Page 1 of 9
