projecotr screen for gunshooter
rebaygsda
PostLink    Posted: Thu Oct 29, 2015 6:53 pm    Post subject: projecotr screen for gunshooter Reply with quote
Laughing hello i got a 1998 in my hiifi Thumbs Up
i want to know what screen to use for gunshooting when i did shoot at screen i got no registered shoots in house of dead on sega saturn but now i have it in top. also what type screen is best for gunshooters games. crt is combatible
what screentype should i choose for a gameshooter
seleco svp 310
 Filesize:  231.27 KB
 Viewed:  7021 Time(s)
tschaeikaei
PostLink    Posted: Thu Oct 29, 2015 10:38 pm    Post subject: Reply with quote
Buy a bigger bore gun, the screen is still lighted.
PostLink    Posted: Fri Oct 30, 2015 7:58 am    Post subject: Reply with quote
You need to turn the blue tube up a bit for gun games, the Guncons work best, the Saturn guns need a fair bit of blue brightness.
I had the Saturn guns working fine on my XG and 9PG, if your screen is too big you wont get it bright enough.
rebaygsda
PostLink    Posted: Fri Oct 30, 2015 6:07 pm    Post subject: Reply with quote
Embarassed i failed my screen i got no hits i dont know what to do i got to the ... on seleco remote hold it for 2 seconds and press exit 7 times go to video options in installation mode set brightnees and blue stretch dont know that to do do i have to buy something image brightner? can you show me in manual on cuurtepalme seleco 310 350
no hit
 Filesize:  142.43 KB
 Viewed:  6935 Time(s)
PostLink    Posted: Fri Oct 30, 2015 6:14 pm    Post subject: Reply with quote
The projected image may be too dim for the photocell in the gun to register. You may need to go to a smaller image.
rebaygsda
PostLink    Posted: Fri Oct 30, 2015 8:29 pm    Post subject: Reply with quote
guncon 2 works on ps2 slim i think my playstation will work in guncon not sure about namco blaster Very Happy going to buy a ps-io.com/ for this Laughing
 Filesize:  119.67 KB
 Viewed:  6917 Time(s)
PostLink    Posted: Sat Oct 31, 2015 3:59 am    Post subject: Reply with quote
That Seleco will be a bit small for the job if the screen is over 70 inch, as good as the 07MS tubes are for this purpose theyre just not that bright.
What you need to adjust is the blue level at the white end of the scale, leave the blue dark end of the scale dark.
PostLink    Posted: Sat Oct 31, 2015 4:04 am    Post subject: Reply with quote
... By moving the projector closer to the screen. Smaller image on its own wont change anything if the projector is still too far away.
rebaygsda
PostLink    Posted: Sun Nov 01, 2015 2:28 am    Post subject: Reply with quote
i get blurry image. i dont know how to get sharp image
using hdmi to rgb to composite
 Filesize:  219.75 KB
 Viewed:  6827 Time(s)
rebaygsda
PostLink    Posted: Sun Nov 01, 2015 3:23 am    Post subject: Reply with quote
i also want to buy ii did read on the forum time ago about seleco converted to automatic calibration since this one was to adjust with screw inside es lens?
PostLink    Posted: Tue Nov 03, 2015 9:03 am    Post subject: Reply with quote
You cant change that Seleco to auto set up.
You need to focus the lenses if you move the projector, the front knob does corner focus, rear knob does centre.
Seleco projectors are pretty ordinary machines, if an NEC comes up theyre a huge step up.
rebaygsda
PostLink    Posted: Wed Nov 04, 2015 8:18 pm    Post subject: Reply with quote
i asked hifi and them dont know about this machine anymore
rebaygsda
PostLink    Posted: Wed Nov 04, 2015 8:55 pm    Post subject: Reply with quote
so i adjust the two magnetic yoke ring to center and focus for smaller screens i cant move it with my finger after unscreving it. will a tube brightner crt fit a 07MS tubes. can i find a rgb connector board that can take hdmi source to 15 khz and i get sharp image for computer?
PostLink    Posted: Wed Nov 04, 2015 11:10 pm    Post subject: Reply with quote
Hey case, do you think a screen with high gain like the old Sony's convex would work well?
http://www.ebay.com/itm/Vintage-Sony-Projection-Video-Screen-VPS-500-49-Was-Used-w-VPP-2000-TV-/141803907247?hash=item21042be8af:g:ikgAAOSwjVVVmEgj
rebaygsda
PostLink    Posted: Thu Nov 05, 2015 9:13 pm    Post subject: Reply with quote
looking nice. i can move yoke rings by moving lens after unsrewing it. i have missing spacers. i also dont know how to flip the image to me it looks like connectors those cable have named wires like blu blu brown but its already in place im planing have this as 60 inch for shooter games. maxvell hifi could set this up for me
PostLink    Posted: Fri Nov 06, 2015 11:08 pm    Post subject: Reply with quote
Absolutely, thatll work well. You need enough black level, but it is important to have high enough blue at the top end too, as when you see that white flash the gun only really sees the blue to give the signal Smile
rebaygsda
PostLink    Posted: Sat Nov 07, 2015 11:41 am    Post subject: Reply with quote
only problem there is a small metall pice to asjust distance do lenses i dont have those and there are smaller ones buut for 60 inch any wrong spacer piece and the red blue do not hhit the green line and is out off focus after adjusting the yokes or diffuse Question Question Question
PostLink    Posted: Sun Nov 08, 2015 8:14 am    Post subject: Reply with quote
I dont know what youre trying to adjust, but the knobs on the lenses are all you needed to change for the focusing.
PostLink    Posted: Sun Nov 08, 2015 3:26 pm    Post subject: Reply with quote
Lens spacers?
PostLink    Posted: Mon Nov 09, 2015 9:49 am    Post subject: Reply with quote
Yeah, sounds like he is touching astig rings though too!!
