3D Theater and 4K
DanLShane
PostLink    Posted: Mon Sep 28, 2015 12:21 am    Post subject: 3D Theater and 4K Reply with quote
I own a Vizio M70 LED UHD flat panel TV that uprezzes everything to 4K. Should I expect any problems displaying 720p 3D with the 3D Theater?
PostLink    Posted: Mon Sep 28, 2015 12:35 am    Post subject: Reply with quote
Nope - it should simply take the resolution (720p or whatever) and upconvert as you mentioned. Most displays do do some form of upconversion.
To order, see: http://www.curtpalme.com/3DTheatre.shtm
DanLShane
PostLink    Posted: Thu Oct 22, 2015 8:07 pm    Post subject: Reply with quote
Thanks for the reply Kal,
I received my kit, and the 3D effect is magnificent on my Vizio 4K set. However, I'm a bit confused about tuning the RF emitter. I watched some videos on the 3D-Now Web site that describe presets on the emitter for various kinds of TVs to reduce the flicker on my 60 Hz TV. Supposedly tapping the joystick to the left twice will cause the two outermost LEDs to blink as the emitter enters the presets tuning mode, however my unit does not do so. I seem only to be able to access manual mode.
Is the emitter indeed supposed to come with presets, or are the 3D-Now products different? I want to get the flicker to an acceptable level, but I also want to be sure of the correct method of doing so.
PostLink    Posted: Thu Oct 22, 2015 8:23 pm    Post subject: Reply with quote
Hi Dan,
Could you email me at kal@curtpalme.com with your order information? (Simply forwarding your order confirmation email is fine). I don't have any records of you ordering from us.
Thanks!
