Hi folx,
so far I had the mome board in my Sony VPH 1292 running as a Sony FW-900 monitor using a fixed .inf.
However I upgraded my machine with a GTX 980 board. I had to re-install all stuff from scratch - and even worse, cannot find that .inf anymore.
I was running 1920x1080x96 Hz, which is clearly the limit of that mome card. However, that looked very good in 3D, using classic crystal eyes shutter glasses.
How can I get there again !?
Getting a fake .inf into that monitor is easy, even that windows loves to swap the monitors randomly. If I got a Viewsonic .inf that I found online running, I get 1920x1080x60, and the nVidia driver even shows me: Generic CRT. I start the 3D Demo, but only in 60 Hz. When I try to create a custom mode with 96 Hz - or even with 75, I only get a garbled screen
Same when I put in the parameters windows shows, when I create a custom 96 Hz mode in the default PNP Display mode.
In that mode, windows only allows checkerboard or 3DTV mode
If I patch the .inf, put the stereo to CRT mode, then put back in the right .inf for the moome, I get a nasty crash
Anyone has any idea !? Solution !? Help !? Hugz !?!?!?
Cheers
Ralph
Joined: 17 Jun 2008 Posts: 464 Location: Berlin/Munich
Link Posted: Wed Aug 05, 2015 4:53 pm Post subject: Re: no 3D with nVidia anymore
biggoldensun wrote:
Hi folx,
Cheers
Ralph
Hello,
you can enable CRT mode with any Forceware drives - but it differs how hard it is to enable them. That includes registry hacks and using .inf files from 3D Vision supported devices. I do not know your technical knowledge level, but for 3D Video playback revert back to a Nvidia Forceware before 285. Also use a Acer 3d inf to set Nvidia 3d Vision into DLP mode. DLP mode means frame sequential (96hz100hz/120hz/ or whatever you like and can configure).
