KPV
Link Posted: Wed Mar 18, 2015 3:43 pm Post subject: Help with Moome IFB-FullHD V3 card in a Sony VPH-D50HTU MkII |
Hi Guys!
I have been away for a while, but today, I actually need some help and was hoping someone might have the insight.
Last year I bought the IFB-FULLHD V3 card and installed it in Input B of my Sony VPH-D50HTU MkII projector. I wanted the HDMI connection to use with a BluRay player and also with AppleTV.
When I installed the card, I was never able to test it. I got very busy and haven't used the theater in a long time. Yesterday, I was trying to use it and I could not get Input B (IFB-FullHD V3) to work.
This is my setup….
1. Sony VPH-D50HTU MkII with wired full-size remote
2. Input A: Factory card with component (RGBHV) BNC connectors
3. Input B: IFB-FullHD V3 card with HDMI cable
4. Sony BluRay player connected to Input A via Component (RGB) Video connection. BluRay DVD’s play properly, however, regular DVD’s flash on and off.
5. AppleTV OR Same Sony BluRay connected to Input B via HDMI cable (My intent is to swap the cable depending whether I use the DVD player or AppleTV)
When I change the Sony BluRay player to HDMI output and switch the VPH-D50HTU MkII from Input A to Input B, the display says “No Input”.
So, my question is....what am I doing wrong that the HDMI connection doesn’t work?
I could really use some help. If anyone has any ideas, please share your insight.
Thanks in advance,
Ken
_________________ MAIN THEATER:
Sony BDP-N460 Blu-Ray Player
Sony VPH-D50HT MkII CRT Projector
Proceed Preamp
AVI Amp
Martin Logan Speakers
Sunfire Signature Subwoofers
SECONDARY THEATER:
LG BD370 Blu-Ray Player
Sony VPL-VW10HT LCD projector
Sony STR-DN1000 AV Receiver
KPV
Link Posted: Wed Mar 18, 2015 6:38 pm Post subject: |
OK, so, I was playing with a few settings in the service menu and I got it working for the BluRay HDMI connection. Looks great!
..............BUT................
When I connect to the Apple TV it displays an error message that says..
Frequency is out of range!
This input signal cannot be projected as the frequency is out of range!
Any thoughts??
Proceed Preamp
AVI Amp
SECONDARY THEATER:
KPV
Link Posted: Wed Mar 18, 2015 8:17 pm Post subject: |
Here is a shot of the message...
106.72 KB |
8080 Time(s) |
Proceed Preamp
AVI Amp
SECONDARY THEATER:
Link Posted: Fri Mar 20, 2015 12:58 am Post subject: Re: Help with Moome IFB-FullHD V3 card in a Sony VPH-D50HTU |
KPV wrote: | Hi Guys!
5. AppleTV OR Same Sony BluRay connected to Input B via HDMI cable (My intent is to swap the cable depending whether I use the DVD player or AppleTV)[/list]
Ken |
4. Turn of 24fps in the bluray player
5. The apple TV is probably seeing the edid in the Moome ( the chip with the resolution/refresh info) and setting itself to 1080p which is too much for the projector.
See if you can switch the Apple to 720P instead
And try the bluray at 1080i
Link Posted: Fri Mar 20, 2015 1:11 am Post subject: |
Hi Ken - you emailed us as well. In case you didn't see the responses, here they are:
Quote: | From: Kal [mailto:kal@curtpalme.com]
Sent: March 19, 2015 4:18 PM
Subject: RE: IFB-FULLHD V3 Question
Hi Kenneth,
To add to what Moome mentioned: His card supports any resolution up to 1080p. Your projector however does not.
Most Blu-ray player and other sources by default will try to automatically detect what the display can support so in this case it sees the display as 1008p / 24 Hz capable since the card supports this.
You need to set your sources to a lower resolution (720p or 1080i) and disable 24Hz too (choose 60Hz). For complete details refer to your Blu-ray player or other source manuals.
CurtPalme.com Home Theater
Sent: March 19, 2015 2:15 AM
Dear Kenneth:
Please make sure :
1. Set input B as RGB input mode
2. the resolution of bluray player and AppleTV are set to 720P 60Hz or 1080i 60HZ, D50 can not handle 1080P due to bandwidth limit.
thanks |
Jeremy's exactly right: Your projector doesn't support 1080p or 24Hz (no CRT projector supports 24Hz). You need to set your source to a resolution/refresh rate supported by the projector.
KPV
Link Posted: Mon Mar 23, 2015 4:30 pm Post subject: |
Hi Guys,
Thanks for the help. I changed the output frequency in both Apple TV and the DVD player. That solved it. Thank you very much for the help.
I do have another UNRELATED question. But, I figured since I have a somewhat captive audience, I may as well ask. I watched Interstellar via AppleTV and the bass was very underwhelming. I am running two Sunfire Signature subwoofers and they usually rattle the house with nearly all other material. However, that was not the case with Interstellar. The irony is that Interstellar has some of the lowest, taxing, bass in any film to date. With Hans Zimmer's organ music, i was expecting something better. I will be buying the DVD as well next week and hope that is better. But, in the meantime, anybody have any thoughts on this?
Proceed Preamp
AVI Amp
SECONDARY THEATER:
