Audio_Geek_00
Link Posted: Sat Feb 21, 2015 12:55 am Post subject: Pis of re-tubing my Sony 1252Q |
Thought I would share these. Even tough it seemed a bit daunting at first, putting in the new tubes turned out to be a fun project. If the PJ hadn't worked after what I had done then not so fun.
123.9 KB |
7672 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 12:57 am Post subject: Re-tubing |
Nice and shiny!
129.6 KB |
7671 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 12:59 am Post subject: re-tube |
What a ball buster to get this down without adding more repair work. it was more of a controlled drop than anything.
109.93 KB |
7670 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:00 am Post subject: re-tube |
No wonder I've been sneezing.
142.16 KB |
7669 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:03 am Post subject: re-tube |
I have to admit when I took off the covers I got intimidated again. Fortunately the manual shows how to remove what to get out the tubes out. The chassis looks like a nightmare but it is made to be serviced with very few screws need removal (except the video boards and heat sinks).
150.37 KB |
7667 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:06 am Post subject: re-tube |
I took pictures of everything I would be taking apart so that I had a handy reference. Especially handy when dealing with cables and such. This is the green gun.
115.87 KB |
7664 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:08 am Post subject: re-tube |
Lenses' out. I should have done this before I took the PJ off of the ceiling. It takes about 35lbs off.
121.47 KB |
7662 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:10 am Post subject: re-tube |
Getting my nerve up to disconnect the yoke harnesses from the tubes.
134.37 KB |
7652 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:11 am Post subject: re-tube |
Don't get the colors mixed up.
107.88 KB |
7651 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:13 am Post subject: re-tube |
They follow the same logic on all three tubes.
133.59 KB |
7649 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:16 am Post subject: re-tube |
Tubes are out. I got really nervous at this point. I wasn't sure how badly I could screw this up but there looked like a lot of opportunity. I was worried I'd break something trying to remove the yoke assembly. The old tape didn't want to let go. But it is not quite as fragile as I thought and I was able to persuade them to come off.
113.81 KB |
7647 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:18 am Post subject: re-tube |
Yoke assemblies transferred to the new tubes.
140.42 KB |
7647 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:19 am Post subject: re-tube |
Tube assemblies re-installed.
161.28 KB |
7645 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:22 am Post subject: re-tube |
Back on the ceiling. Not having the lenses installed help tremendously, although it adds difficulty putting the lenses in.
130.44 KB |
7644 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:23 am Post subject: re-tube |
Raster adjustment.
107.99 KB |
7643 Time(s) |
Audio_Geek_00
Link Posted: Sat Feb 21, 2015 1:28 am Post subject: re-tube |
Lenses installed. Now the real fun begins. I used the CRT setup video to go through my PJ. I did OK but feel like it could be better. But overall I'm really happy with the added clarity and brightness. It perked the ole girl up a bit for not much money at all. Consider doing it if you can get a new set of tubes at a good price. It makes a worthwhile difference.
Best
Tim
113.26 KB |
7641 Time(s) |
Link Posted: Sat Feb 21, 2015 11:46 am Post subject: |
Well done mate, bet its much sharper now
Audio_Geek_00
Link Posted: Mon Feb 23, 2015 6:28 pm Post subject: |
Yes, much sharper and a bit brighter.
Jeremy112
Link Posted: Mon Feb 23, 2015 6:58 pm Post subject: |
nice work
the very first CRT projector I ever worked with and setup was a 1272, had I replaced the tubes as you did, I'm sure it would have looked a lot better. I only paid a $1 for it though so I couldn't complain, it was a really easy to learn projector and fun to use.
Enjoy your new tubes
Audio_Geek_00
Link Posted: Tue Feb 24, 2015 10:52 pm Post subject: Thanx |
1$? Good deal! Yah, as far as these projectors go they are pretty simple.
The only reason I would consider getting rid of this PJ is 4k. The tubes bought me a year or two until more content is available. Someone may get it for quite cheap at that point but until then it will get me through.
