Does a Lumagen HDP upconvert from analog video to DVI?
PostLink    Posted: Sat Dec 27, 2014 4:04 pm    Post subject: Does a Lumagen HDP upconvert from analog video to DVI? Reply with quote
I feel kinda dumb asking this, but I've never done it before...
Does the Lumagen HDP upconvert to the DVI output from the analog inputs?
thanks!
HogPilot
PostLink    Posted: Sat Dec 27, 2014 4:12 pm    Post subject: Reply with quote
Absolutely - it will also convert digital inputs and output them via analog, as long as the original digital signal wasn't HDCP protected. See more in the user's manual here.
PostLink    Posted: Sat Dec 27, 2014 4:18 pm    Post subject: Reply with quote
OK, thanks!
PostLink    Posted: Sun Dec 28, 2014 4:48 am    Post subject: Re: Does a Lumagen HDP upconvert from analog video to DVI? Reply with quote
thanks!
Be sure you have enabled DVI out as it can be turned off. So if you get nothing from the DVI port thats probably the case. You enable output to either DVI or RGBHV or both.
What Lumagen are you using as my experience is only with PRO HDP and the HDQ
