Sony card in a Marquee?
koldby
PostLink    Posted: Thu Dec 25, 2014 4:41 pm    Post subject: Sony card in a Marquee? Reply with quote
Hi
I have a moome card in my Sony G70 and was wondering if I could use it in a Marquee 9500.
Probably some modifications are needed, but is it possible?
PostLink    Posted: Mon Dec 29, 2014 8:20 pm    Post subject: Reply with quote
Its possible, but wont look to fancy.
koldby
PostLink    Posted: Wed Dec 31, 2014 2:13 pm    Post subject: Reply with quote
Thanks Kurt
Looks like you actually have tried it?
Is the width and depth of the cards the same?
Looks like the edge connectors mate and if so you could cut the appropriate pins going from the edgeconnector to the pcb and make the right connections on the moome card and all there is left is making a new faceplate matching the cutout in the Marquee..
koldby
i
What is home theater without good sound?
PostLink    Posted: Wed Dec 31, 2014 2:42 pm    Post subject: Reply with quote
koldby wrote:
Thanks Kurt
koldby
i
The dept dont match, and you need to take the 14V from the VIM as its not present in the DIN. 96 connector into the VIM. ( that i have been able to find)
It would be better to sell the sony card and buy a Marquee card.
I did run the new SONY card in my Marquee for some time, and when installing the right filters out of the DAC, it performs the same as the Marquee card, as expected, as its the same DAC and buffer used, i guess the difference is that the SONY card have the 3D stuff on it.
PostLink    Posted: Wed Dec 31, 2014 6:28 pm    Post subject: Reply with quote
or you can look for a sony switcher and put the Sony card in that and run RGBHV to both PJ's with one card if your using both projectors that is. but it still work with the marquee.
nashou
koldby
PostLink    Posted: Thu Jan 01, 2015 11:35 am    Post subject: Reply with quote
nashou
That might be a good idea.
Do you have a model number for such a switcher?
Will there be a performance degration with that solution?
koldby
PostLink    Posted: Thu Jan 01, 2015 12:00 pm    Post subject: Reply with quote
nashou
koldby
There for sure is a potential performance degradation.
And i would think its a bit silly to spend money and time, to get a switcher, when there is a Marquee card who fits right into the projector, with a minimum of connections and no cable run.
