Hulio
Link Posted: Fri Jan 23, 2015 3:42 pm Post subject: |
Hello Trevor,
It's a shame the second quad died too.
On the "Buy & Sell" section of this forum, a member from Canada is selling a quad R762717 and, more important, a Cine 8 EHT R7627165. I would send him a PM cause they won't be for sale for more than one day, i think ( the EHT is for Cine 9/Max/BR909 too ).
Like i mensioned earlier, a lot of boards in your machine are not genuine Cine 8 boards. Including the EHT.
Do you mind to post a picture of the back-sticker on your Cine 8 ?
Let's hope indeed that Case will be soon ok.
cosaw
Joined: 08 Mar 2006 Posts: 159 Location: Nottingham, England
Link Posted: Fri Jan 23, 2015 3:51 pm Post subject: |
Quote: | Just as an aside, One of the springs has dropped off one of my scan inverter switches, I have just taped it to the chassis (seems to stay put) I tried to put the spring back on but to no avail (must be something to do with the way you hold your mouth) ?? |
Yes, all the springs are working but I think I read about Curt saying he's had to tape switches into position in the past when he hasn't had a spare to hand. I need to get a continuity meter in there to test - certain combinations of the vertical scan switch and one of the horizontal switches (the combination I happen to need) and the tubes won't fire up. Anyway, I'm not bothered about it now and will be onto it sooner or later.
_________________ Simon
dentree
Joined: 01 May 2009 Posts: 247 Location: Melbourne Australia
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
Link Posted: Fri Jan 23, 2015 10:07 pm Post subject: Barco Cine 8 |
Hulio,
Thanks for the heads up about the Quads, I have sent the chap an email, also here is a picture of the back of the CINE 8
323.6 KB |
5347 Time(s) |
dentree
Link Posted: Sat Jan 24, 2015 2:31 am Post subject: |
Hi Casey,
Hope you are feeling better than yesterday, Did think about you, Bought some grapes, they were so nice I actually ate them all (but did think of you as I munched!!!)
Get well soon
Trevor
dentree
Link Posted: Sat Jan 24, 2015 2:39 am Post subject: Barco Cine 8 |
This is my new passion, I have started a collection, at the rate I am going I will have enough for a exhibition before too long !!
488.05 KB |
5322 Time(s) |
Link Posted: Sat Jan 24, 2015 3:10 am Post subject: |
dentree wrote: | Hi Casey,
Get well soon
Trevor |
No mate im worse if anything, still waiting for operation yet.
dentree
Link Posted: Sat Jan 24, 2015 6:02 am Post subject: |
Wow, sorry Casey Didn't mean to be flippant with the 'Grape' thing I should have been a little more considerate, thought you might have been hospitalised for an infection or something (that's all I was in for myself)
Apologies
Trev
Link Posted: Sat Jan 24, 2015 6:24 am Post subject: |
No mate, stomach issues
Its no big deal, think nothing of it!
cosaw
Link Posted: Sat Jan 24, 2015 10:59 am Post subject: |
Quote: | This is my new passion, I have started a collection, at the rate I am going I will have enough for a exhibition before too long !! |
I think everyone on here has got some sort of collection. You only need two of something!
Hulio
Link Posted: Sat Jan 24, 2015 11:09 am Post subject: |
Ok Trev, from the art.nr. i can see that it's a plain Cine 8, without power factor correction and without any form of internal deinterlacer ( lido, limo or limo pro ). It was for the north-american market ( 120V ), so you should check the power input module. Not only the 120-230V jumper must be switched but also those two fuses must be change for future protection. For 230V, 2X6,3A must replace the 2X10A ones.
The former owner(s) make a mess from it, mixing parts from other projectors. Shorter tubes, hence the need to cut some parts to compensate the focus coil, another version of G2 diagnostic board, another version of vert. deflectio and EHT module.
The best way to see if components belong to the projector is to check if the small sticker on each board match the serial nr. on the back-sticker of the PJ ( in your case 1180057 ). Watch the identification menu on screen, the same serial nr. should be found there too. If not, the controller was replaced.
Ofcourse, there is nothing wrong with not maching serial numbers, i only say that when we buy second hand and we have the chance to see the projector before buying, beside a honest seller, this is the only way to see if the machine was trouble-free.
However, there is a big deal when the replacement board does not have the same R76xxxx nr. Your EHT should be R7627165 instead of R762716. No Cine 8 was ever made without the newer version EHT.
I would get rid of Limo and COG modules too, it's just a way to complicate things even more. The internal scaler was designed for SDTV and COG module is for twin channel configuration and, again, no Cine 8 has ever leaved the factory with convergence on green. It makes no sense for HT use.
I hope you can buy the quad and EHT from Canada, the price is right if you ask me.
And good job with the focus issue.
From your last pic. i'll blame the mouse for eating quads
dentree
Link Posted: Sun Jan 25, 2015 1:33 am Post subject: |
Hi Hulio,
Have just given my mouse a good talking to, and it has promised not to eat anymore Quads !!
Thanks for that most valuable information regarding the serial numbers, most interesting, very much appreciated,
I have checked the EHT and Quad numbers here and it seems that the Quad IS an original part, the EHT is NOT original
i mentioned earlier that i noticed that the original Quad (that burnt out (on page 1 of this post) was very hot before it crashed, the replacement that I installed was from my BG 808 which also ran very hot, then gave off the metallic smell before failing (but nothing visible like on the original which showed burning (page 1)
I then fired up a BARCOGRAPHICS 801s which I have not run for 5 years that works perfectly, but the most noticeable difference was that the BG 801s Quad ran very cool to the touch even after 4 hours of running.
I am going to be getting the Quad and the EHT from the Canadian chap, the Quad is the correct number, but the EHT is different, but I will get both all the same, and hopefully all issues will be fixed, I shall also investigate the LIMO in the CINE 8 with the view to removing it, as of yet I have not investigated the rest of the boards ID numbers, but will do that in due course, the only other issue I need to resole is that at present I am running the BG 808 convergence tray as the resistors (as pictured) which are cooked are proving very difficult to find (want to fix this if only as a back up, other than that I am hoping that all will work well, Stefan (the Canadian) tells me it will take about 10 days to get the replacements ............then we shall see what happens, and I will be taking close attention to the heat that the replacement Quad will generate, if anything else comes to mind i would appreciate you letting me know, also obviously my thanks go to all others who have donated their time,thought and effort to this situation, and especially to Casey, and hope his recovery is swift.
Many thanks
Trevor
dentree
Link Posted: Tue Jan 27, 2015 4:04 am Post subject: barco cine 8 |
I have a very early version of a Barco control software program which will not run on Windows 7, has anyone got an updated version of this?
A long time ago I found it very useful for tweaking things while a movie was running as things could be tweaked without anything showing onscreen
Link Posted: Tue Jan 27, 2015 5:52 am Post subject: |
Hulio wrote: | Ok Trev, from the art.nr. i can see that it's a plain Cine 8, without power factor correction and without any form of internal deinterlacer ( lido, limo or limo pro ). It was for the north-american market ( 120V ), so you should check the power input module. Not only the 120-230V jumper must be switched but also those two fuses must be change for future protection. For 230V, 2X6,3A must replace the 2X10A ones.
From your last pic. i'll blame the mouse for eating quads |
I would not agree with removing COG board especially since we know there are issues with the wrong tubes. He may well need to have control on the green pattern to get the best convergence result. He certainly doesn't need LIMO.
Hulio
Link Posted: Tue Jan 27, 2015 9:16 am Post subject: Re: barco cine 8 |
dentree wrote: | I have a very early version of a Barco control software program which will not run on Windows 7, has anyone got an updated version of this?
A long time ago I found it very useful for tweaking things while a movie was running as things could be tweaked without anything showing onscreen |
Just tried V 1.00 on Windows 7 ultimate and runs fine.
Here the zip.
Download |
Filename: |
R32862000_V01_00_Tool.zip |
1.48 MB |
Downloaded: |
173 Time(s) |
Link Posted: Tue Jan 27, 2015 1:55 pm Post subject: Re: barco cine 8 |
Hulio wrote: |
Here the zip. |
x86 or x64 though????
Hulio
Link Posted: Tue Jan 27, 2015 10:13 pm Post subject: |
Windows 7 ultimate x64 version.
RU home and well Case ?
dentree
Link Posted: Tue Jan 27, 2015 10:53 pm Post subject: Barco Cine 8 |
this Laptop is 64 bit,
Unzipped the files, but will not install, I think this must be 32 bit, which I imagine is the same as the old one I had
Link Posted: Wed Jan 28, 2015 12:06 am Post subject: |
Yep, that was my thought
Link Posted: Wed Jan 28, 2015 12:07 am Post subject: |
Hulio wrote: | Windows 7 ultimate x64 version.
RU home and well Case ? |
I am indeed thanks mate, a bit sore from the operation but certainly much better
Hulio
Link Posted: Wed Jan 28, 2015 11:42 am Post subject: Re: Barco Cine 8 |
dentree wrote: | this Laptop is 64 bit,
Unzipped the files, but will not install, I think this must be 32 bit, which I imagine is the same as the old one I had |
Trev, unzip the soft to your desired map and try to install it with diagnostic startup. Click start and type msconfig in the search box, than enter. On the general tab, select diagnostic start up and restart. Try than to install and don't forget to select normal start up after installation.
Oh yeah, another tip : a guy from Point Cook (Seabrook) is selling his non working Cine 7 for 100 AUD on the bay AU.
Quad, splitter and colour filtered HD145 if you want to upgrade.
