Doctor HDMI: EDID Correction Tool
PostLink    Posted: Tue Nov 25, 2014 8:44 pm    Post subject: Doctor HDMI: EDID Correction Tool Reply with quote
Click HERE to order Doctor HDMI today at a CurtPalme.com discounted price
Resolves HDMI video loss / stability issues - replicates a full 1080p, 3D EDID out-of-the-box
Doctor HDMI helps resolve most HDMI video issues caused by faulty EDID handshakes or other incompatibility issues. It's used to keep a source device "always on" by tricking / feeding back to it the same, stable EDID signal. Particularly useful when using HDMI splitters and HDMI distribution systems.
Are you experiencing video loss / video return delays when a TV displays is turned on/off, or when an AV receiver or matrix switcher's inputs/outputs are changed? Doctor HDMI is the answer!
Doctor HDMI can also boost HDMI signal integrity allowing longer HDMI cable runs. It can also be used to limit the source output resolution.
Doctor HDMI solves these and other problems by acting as an EDID manager and HDMI/DVI-D emulator/repeater that comes with pre-defined presets, user programmable banks, EDID sniffing and more.
"As a EDID emulator the Dr HDMI worked flawlessly with my gaming PC. My main desktop PC has its video output split between a monitor and a AV receiver and TV setup. Of course, this resulted in the EDID being incorrectly detected and the PC refusing to output surround sound to the receiver. Using Dr HDMI, it was trivial to capture the EDID from the AV receiver, then by connecting Dr HDMI to the PC, the PC was convinced it was permanently connected to the surround sound system and selecting 7.1 surround sound was no longer a problem." - videogameperfection.com
For complete details see our Doctor HDMI order page.
paw
PostLink    Posted: Wed Nov 26, 2014 8:05 pm    Post subject: Reply with quote
Interesting. Does this product function like a HDCP stripper? SSSSSH!
Aubrey
PostLink    Posted: Wed Nov 26, 2014 8:13 pm    Post subject: Reply with quote
No. See the FAQ on the order page for more details: http://www.curtpalme.com/DoctorHDMI.shtm
clotter
PostLink    Posted: Fri Nov 28, 2014 1:09 am    Post subject: Reply with quote
Is it correct that I would need one of these for each video source? For example, I have a Dish Hopper, DVD player, PS3, and PS4 all connected to my receivers HDMI inputs. The receivers output then goes to my projector. I don't have any issues, but would gladly pay the cost of this unit if it would eliminate the delay when switching inputs on my receiver. I miss the old analog days of instant input changes!
PostLink    Posted: Fri Nov 28, 2014 2:41 am    Post subject: Reply with quote
Good question - You'd need to connect one between each source and the receiver in order to (a) Preserve the EDID that is being transmitted by the source, and (b) Present this same EDID to the sink (the receiver), constantly. (You can also totally remove and inject a "new" EDID if the source device's original EDID is invalid).
THE ISSUES
As many of you may have experienced - if you have multiple "sources" devices set up - such as a cable box, a gaming station, a disc player, and/or a Media System - and the user switches between these devices, there sometimes may be a significant delay for the video to re-appear.
Some may say that it's HDCP handling that causes this - but it may actually be caused by the source and sink devices trying to
"sync up" on the EDID - not due to HDCP.
For example, on a standard DVD player (which has no HDCP that is present on Blu-ray and HD set-top boxes) - this same delay can be observed, and it is obviously not caused by HDCP. Worse - in some cases - with particular source and sink combinations - the video may not even come back unless the source is reset - making it a huge problem for AV integrators and installers!
In some cases, specific combinations of TV & receiver devices will create invalid EDIDs - causing some sink devices/sources to not show video correctly.
... So what's an installer to do?
THE SOLUTION
In these cases, a "fix" is needed to do all of the following to prevent the above issues:
- Preserve the EDID that is being transmitted by the source
- Present this same EDID to the sink, constantly
- Totally remove and inject a "new" EDID if the source device's original EDID is invalid
Since HDMI is becoming more and more prevalent in any installation, a device called the "Dr. HDMI" exists - which helps installers eliminate the above issues in their AV installations. "Dr. HDMI" helps resolve these issues when sources are switched on a TV or receiver:
- Minimize the lag time for video to return
- Help eliminate "loss of video"
- For source devices w. invalid EDIDs, a "corrected" EDID can be injected midstream to allow normal AV operation
Me too. HDMI is the absolutely worst connection type I've seen in 20+ years because when there are issues, you're pulling your hair out.
clotter
PostLink    Posted: Sat Nov 29, 2014 1:30 am    Post subject: Reply with quote
Thanks for the clarification!
wildchild22
PostLink    Posted: Sat Nov 29, 2014 3:43 am    Post subject: Reply with quote
Yes Kal you are correct.
Good question - I would imagine that you'd need to connect one between each source and the receiver in order to (a) Preserve the EDID that is being transmitted by the source, and (b) Present this same EDID to the sink (the receiver), constantly. (You can also totally remove and inject a "new" EDID if the source device's original EDID is invalid).
THE ISSUES
THE SOLUTION
Electrogeek
PostLink    Posted: Sat Nov 29, 2014 4:30 am    Post subject: Reply with quote
Hi
Living in the weird parts of the world i have a problem I'd like to know if this will sort, most of my HDMI video sources are 50Hz and my HD Fury Nano wont tell sources that that is just fine, will this?
Cheers
I have found a use for compact fluorescents hehe
wildchild22
PostLink    Posted: Sat Nov 29, 2014 4:58 am    Post subject: Reply with quote
Hi there
Yes it will as you can write whatever edid bin you like to the dr hdmi.
Electrogeek wrote:
Hi
Cheers
stephanehl
PostLink    Posted: Mon Mar 09, 2015 6:20 pm    Post subject: Need help. Reply with quote
Hello,
i just bought Dr. HDMI as i got a big problem with the recorder EZ recorder 130.
Here is my settings, i have ps2 connected to VP30 then i connect it to EZ 130 but it dont works but i also tried 720p 50/60 hz and also 1080p - 60hz, but it dont worked.
Then i tried these settings
PS2 - component - VP30 - hdmi - Iscan mini - hdmi -EZ recorder 130 - it works.
So i try this new one hope that it works but still not work.
PS2 - component - VP30 - hdmi - Dr HDMI - hdmi cable - EZ 130 - it dont worked.
So anyone can help me.
what is this problem.
Stephanehl
wildchild22
PostLink    Posted: Mon Mar 09, 2015 6:38 pm    Post subject: Re: Need help. Reply with quote
As per our forum
You need to test this to a hdmi display for a test.
So try vp30 to dr hdmi to a display.
stephanehl wrote:
Hello,
Stephanehl
Frank D
PostLink    Posted: Wed Nov 02, 2016 5:24 am    Post subject: Reply with quote
Would this item be able to fix a slow sync issue of a blu ray player set to output 24p to a JVC RS 500 ie when playing blue ray some intro material is shown at 1080p60 and some at 1080p24 causing a slow sync issue with the JVC as it changes from one to the other causing a loss in video (but you still hear audio) until JVC syncs to change in sync?
PostLink    Posted: Wed Nov 02, 2016 2:52 pm    Post subject: Reply with quote
Yes, in theory that is one of the purposes. See the section called "What is EDID? What EDID problems exist?" here: http://www.curtpalme.com/DoctorHDMI.shtm
Now, I say "in theory" because if you read here, someone else did not have good results:
http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/2222586-official-jvc-rs600-rs500-x950r-x750r-x9000-x7000-owners-thread-100.html#post40109202
Frank D
PostLink    Posted: Wed Nov 02, 2016 8:56 pm    Post subject: Reply with quote
Wondering if anyone in the GTA has one that I can test or try?
There seems to be a return policy if the unit does not work so that is good.
PostLink    Posted: Wed Nov 02, 2016 8:58 pm    Post subject: Reply with quote
Afraid I don't know.
Correct. It has to be shipped back to Taiwan.
