huggy
Joined: 02 Aug 2008 Posts: 927 Location: Melbourne,Australia
Link Posted: Thu Jan 01, 2015 11:58 am Post subject: |
Ok there's something wrong with this blue, no matter what i do i cant get the 4 pole right, no matter how muxh i twist and turn the magnet i just cant get the diagonal flare right, any tips?
Link Posted: Thu Jan 01, 2015 12:02 pm Post subject: |
Did you null the magnets so they have no effect?
Check all the electronic zones on the blue to make sure theyre 49 on both 4 and 6 pole.
huggy
Link Posted: Thu Jan 01, 2015 12:14 pm Post subject: |
Null the magnets? How the heck do i do that? Remember this is my first ever attempt
Link Posted: Thu Jan 01, 2015 11:29 pm Post subject: |
Twist the little handle that you use to move them
huggy
Link Posted: Mon Jan 05, 2015 12:45 pm Post subject: |
I cant access my mabuals so can someone point me to where the horizontal raster shift for red tube is please, when i changed frim floor to ceiling mount everything got messed up and now dont have enough range to move red in centre of tube.
_________________ Proud owner of stacked 909's on a 12 ft wide 16:9 screen.
Link Posted: Mon Jan 05, 2015 10:33 pm Post subject: |
That should be on the horizontal shift board.Should be two tiny screws facing the top of the board as you look down one for red and one for blue. There are also two on the vertical board.
huggy
Link Posted: Mon Jan 05, 2015 11:28 pm Post subject: |
If you mean the Horizontal def board,then no, there are no pots on there to turn, well none that I've been able to see anyway.
There are vertical size and shift pots on vertical def board but nothing anywhere I can find for horizontal shift, it's weird though,everything was perfect when floor mounted but once I switched over to ceiling mount,everything went to sh*t
Link Posted: Mon Jan 05, 2015 11:37 pm Post subject: |
Not there on 909 that ive seen.
Center your fine raster shift, then center the raster with the coarse shift.
Link Posted: Mon Jan 05, 2015 11:40 pm Post subject: |
H shift and focus on 808 whoops.
Link Posted: Mon Jan 05, 2015 11:44 pm Post subject: |
The vertical board is the same though so those adjustments for vertical shift are on the vertical board.
Link Posted: Mon Jan 05, 2015 11:55 pm Post subject: |
Is the horizontal raster position an electronic adjustment via a menu?
huggy
Link Posted: Tue Jan 06, 2015 1:14 am Post subject: |
problem is the red raster runs out of adjustment before its even close to centre of tube.
Link Posted: Tue Jan 06, 2015 2:33 am Post subject: |
There isn't an internal trimpot. Have you adjusted the raster shift in the geometry menu, which I think has more range than in the convergence menu?
Link Posted: Tue Jan 06, 2015 7:18 am Post subject: |
What about when you go through the setup menu?
huggy
Link Posted: Tue Jan 06, 2015 7:19 am Post subject: |
Yes I completely forgot that
I keep forgetting there are red and blue raster shift in geometry as well, all good now
Link Posted: Tue Jan 06, 2015 7:20 am Post subject: |
Yes, the one in geometry has coarse and fine under RASTER SHIFT, in coarse you can only shift left and right for blue and red.
Link Posted: Tue Jan 06, 2015 11:54 am Post subject: |
CasetheCorvetteman wrote: | Yes, the one in geometry has coarse and fine under RASTER SHIFT, in coarse you can only shift left and right for blue and red. |
Well that's it then Dave as suggested. As mentioned though there are trim pots for vertical blue and red on the vertical deflection board.
huggy
Link Posted: Tue Jan 06, 2015 4:29 pm Post subject: |
Well I've been lazy lately so bout time I threw up some pics of the never ending HT build. I have the black wall panels, custom lounge on order and star ceiling to put together, fun!
bulkheads for led lighting |
164.8 KB |
4514 Time(s) |
240.02 KB |
4514 Time(s) |
166.38 KB |
4514 Time(s) |
Black velvet covering bulkheads |
174.58 KB |
4514 Time(s) |
over 1000 lbs of speakers and subs |
187.69 KB |
4514 Time(s) |
123.78 KB |
4514 Time(s) |
202.94 KB |
4514 Time(s) |
154.64 KB |
4514 Time(s) |
Link Posted: Tue Jan 06, 2015 4:56 pm Post subject: |
Very nice.
