thewolfman
Link Posted: Fri Oct 24, 2014 9:28 pm Post subject: |
redfox001 wrote: | Yeah you have 3 now! |
Thanks there.. I saw that! I'm @ 8th place now.
GREG1292
thewolfman
Link Posted: Sat Oct 25, 2014 3:12 pm Post subject: |
I appreciate it, thanks.
napos
Joined: 21 Oct 2006 Posts: 164 Location: Athens, Greece
Link Posted: Sat Oct 25, 2014 6:48 pm Post subject: |
You have 5 now!!!
_________________ Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
thewolfman
thewolfman
Link Posted: Wed Oct 29, 2014 10:37 pm Post subject: |
I'm tempted to cut off the clamps in the front on Frankenyokes and move them further forward. I think the image could get a little bit sharper doing that.
I have tested before, what happens when moving them backwards and forwards, and it's plain obvious they should be as far forward they can because the center upper and lower grid pattern lines gets thinner doing that. Right at the top and bottom they tighten up and almost positive they could get tighter still. Maybe just pipe-dream of mine..
I actually regretted putting the chassis back together last week because I wanted to have another look at them just now. But pretty certain there is room to move them forward by like >10 mm. Not much, but tempting all the same.
If I remember correctly, there's a clamp on the back but also some protruding plastic on the front that I want to remove. Doing that I would have to tape around the tube neck with fibreglass tape and then sort of snug the Franks back on again. There are other ways to but that one should be the easiest. But then again, why mess with something that already works..
Anyway, to easy my itch I made the smallest Thomson coils that I could make. Inc. magnets, I got them down from 11,5 cm to only 8,5 cm. With silicon I could make them even smaller by another 4mm. They are kinda cute now.
But.. the coil itself hasn't moved further forward it's just the housing that has shrunken. However, the magnet behind it has moved forward, very much so, and I wonder what that will do for the image. Maybe a test on an old tube some day.
Btw, the magnet would be glued/siliconed onto the coil plate that I flattened out.
680.99 KB |
5117 Time(s) |
redfox001
Link Posted: Wed Oct 29, 2014 11:08 pm Post subject: |
Nice! I have a set FY comming just to see for myself and they are not that expensive for an experiment. Further forward yes I read that too.
thewolfman
Link Posted: Wed Oct 29, 2014 11:17 pm Post subject: |
redfox001 wrote: | Nice! I have a set FY comming just to see for myself and they are not that expensive for an experiment. Further forward yes I read that too. |
Ok, so you went for them after all. Cool! I really like to hear what you have to say about them. Is it Emperors cloth or not..
redfox001
Link Posted: Wed Oct 29, 2014 11:28 pm Post subject: |
thewolfman wrote: | redfox001 wrote: | Nice! I have a set FY comming just to see for myself and they are not that expensive for an experiment. Further forward yes I read that too. |
Ok, so you went for them after all. Cool! I really like to hear what you have to say about them. Is it Emperors cloth or not.. |
Yes but these are 1292 yokes I read through the whole thread but I do not know if I can make the 1292 yoke housing smaller or do I have to use Thomson housings?
thewolfman
Link Posted: Wed Oct 29, 2014 11:38 pm Post subject: |
Mine are also 1292s that I bought from Canada, but before posting this, I looked at them again on the Interweb and some pictures seems to not have the protruding plastic at the front as I have (?) which in that case makes them useless to make smaller.
Unless of course they too have much hollow insides as the Thomson's.. if so, then there is much to be made there too. I never opened mine up.. mostly because there is silicon on them. But will definitely look into it more next time the chassis is off.
Link Posted: Thu Oct 30, 2014 1:21 am Post subject: |
redfox001 wrote: |
Yes but these are 1292 yokes I read through the whole thread but I do not know if I can make the 1292 yoke housing smaller or do I have to use Thomson housings? |
No you don't use the Thomson housing.
The way you can tell where the best location on the tube face is with any coil it to move it up and down the tube face with out the electronics connected to them. Where the grid is the sharpest is the best spot for the focus coil. Once again finding this spot will allow you to use less electronic correction for focus. However over time the magnets in the focus coils loose their strength, that is where the electronic correction comes in. One thing you might notice is the rater might tilt. Rotating the FY around might level it out. if not then you need to correct the deflection by removing the glue on the Deflection Coil and level the raster. Be careful as there is up to 1000 volts on the Deflection coil. You can cover the exposed pins with silicon for protection.
thewolfman
Link Posted: Thu Oct 30, 2014 1:54 am Post subject: |
Nashou66 wrote: | Why did you cut them down? There is a reason they have that open space. It is so you can move the coil around in different directions to help center the raster mechanical on the tube face. This helps minimize how much electronic correction you need, therefore putting less strain on the electronics and reducing heat on the boards.
Nashou |
I know. But you can still do that except you loosen the wing nuts and pivot. The holes needs to widen though to fit all four sqrews instead of only 3. And the magnet clamp is what's holding it up now and a really strong glue or silicon. So it's still 2 parts and just a test to see what will happen. I'm not going to destroy my FY without testing on these first. That's the idea anyway.
redfox001
Link Posted: Thu Oct 30, 2014 7:18 am Post subject: |
I found it encouraging to read that a trustable person said in the FY thread that the thomson deflection yoke has better astig in the corners than the barco/sony deflection yokes because of the way it is wound. So they should need less astig correction.
Another thing is you seem to have the 4-pole astig rings. The marquee has 6-pole available the barco does not go beyond 4-pole. You only need them if you have triangular spots. On the 6-pole I see three turning knobs.
To sum it up. The marquee has better static astig from the rings till the deflection it seems.
redfox001
Link Posted: Thu Oct 30, 2014 7:42 am Post subject: |
One question. Where the Barco 909 focus yokes ever tested? In Mike's thread he seems to end with 909 focus and thomson convergence/deflection and the 909 astig rings.
I can test these combinations in the near future if not done allready.
thewolfman
Link Posted: Thu Oct 30, 2014 11:33 am Post subject: |
redfox001 wrote: | I found it encouraging to read that a trustable person said in the FY thread that the thomson deflection yoke has better astig in the corners than the barco/sony deflection yokes because of the way it is wound. So they should need less astig correction.
To sum it up. The marquee has better static astig from the rings till the deflection it seems. |
I have 3 sets.. 2-pole, 4-pole and the 6-pole that I use in my projector. With the new blue I got triangular spots indeed so I had to learn how to use 6-poles, but I got them round again.
As for your other questions you had I'm not qualified to answer that.
All I know is, my FY needs to be as far forward they can be so there's no need to look for the sweet spot with these. I use the magnets to centralize the grid-pattern on the tube face. BUT, I have never used the unhooked cables procedure yet, maybe that will change things a bit.
And with the Thomson I never used them in the correct manner, as they too were pushed all the way forward, and at the time I wasn't aware they should be seated at the sweet spot either. Or didn't care. But I've had FY almost since I bought the machine so I never really cared for that procedure anyway.
redfox001
Link Posted: Thu Oct 30, 2014 12:44 pm Post subject: |
Ok. But it becomes clearer to me how to position the focus yoke. With the barco the electronic focus was set on 58 and than the sweetspot was found. That way the focus on the upper/lower zones was 20 or so and the static area was somewhere around the center. Guess this means that with the wires disconnected the yoke should be a little underfocussed?
thewolfman
Link Posted: Thu Oct 30, 2014 1:25 pm Post subject: |
I don't know how it will look with the wires disconnected, but everything is set to 50 before doing anything.
But I'll tell you one thing.. I always struggle to fill the screen with porches and stuff and looking at how my RGB-focus looks like I wonder if the pj is to far forward.
RGB-focus is - top and bottom only, about 7.. sides are at 100. Centre is around 21.
I'm lucky that right side is very good with 100 and even slightly less.. but left side is the weaker one. Also at 100 but could have used like 105-110 to make it silly sharp. That makes me wonder..
1. Do I have the pj to far forward?
2. Do I have the pj absolutely dead straight forward? Would that matter?
Lensflap is as good as it gets so I know it's not that. But I wonder if the numbers will go down a bit if I moved the pj further backwards by like 10-20 cm.
Link Posted: Thu Oct 30, 2014 1:34 pm Post subject: |
redfox001 wrote: | Ok. But it becomes clearer to me how to position the focus yoke. With the barco the electronic focus was set on 58 and than the sweetspot was found. That way the focus on the upper/lower zones was 20 or so and the static area was somewhere around the center. Guess this means that with the wires disconnected the yoke should be a little underfocussed? |
If you have the focus wires disconnected you will be able to tell how well the static focus of your magnets are. They might be to strong or too weak. The electronic adjustment either adds or subtracts the magnetic field of the focus yoke to compensate for magnets that might be off specifications.
So to make things easier on the focus circuit finding the optimal location for the magnets is key. Once that is found
lock them in.
This works for all PJ's that use the Sony/Barco style yokes. With the marquee coils they need to be left as is as they need to be pushed up to the convergence coil for proper set up.
redfox001
Link Posted: Thu Oct 30, 2014 1:55 pm Post subject: |
Ok thanks. I do not have to shift these thomson coils.
But in Wolfman's case would it be an idea to set the electronic focus at 40 and find the sweatspot so that the correction that is now beyond 100 will be beyond 90 or so?
