MOOME V3 ext 3D is not working... Still....
PostLink    Posted: Sat Oct 04, 2014 5:20 am    Post subject: MOOME V3 ext 3D is not working... Still.... Reply with quote
For some reason, when I set 3D mode on, I either get no image and a red LED blinking slowly about every 2-3 seconds, and if I get an image, it is one above the other.
Doesn't matter which resolution I set the OPPO 103D to, it does the same thing. Tried both HDMI inputs, same thing again. It isn't displaying the image in 3D, pushing the MODE button on the remote has no effect, setting the OPPO to auto 3D or FORCE 3D makes no difference either.
What is required to get this device to work the way it is advertised???
BGSPCS
PostLink    Posted: Sun Dec 28, 2014 5:29 am    Post subject: Reply with quote
Did you ever get this resolved? I'm having issues getting a 3D sync signal out of the EXT V3. I am using a Lumagen XE as the input to the EXT V3. I have been in contact with Moome and need to do some probing on the board. I can drive the 1200X at 720P 100HZ and get a 3D image but no sync coming out of the EXT v3 box.
Brad S
Pottstown PA
PostLink    Posted: Thu Jan 08, 2015 5:14 am    Post subject: Reply with quote
No mate i never did.
PostLink    Posted: Thu Jan 08, 2015 6:23 pm    Post subject: Reply with quote
I know that on the EXT there is a little solder job you can do to make the thing transmit 3D for ALL inputs signals. That way your 3D will work with custom resolutions, but it will also be on for 2D stuff. I had one client with a Marquee we setup like this. I don't remember the mod though.
Might be worth mentioning in an email to Moome.
ElTopo
PostLink    Posted: Thu Jun 18, 2015 5:17 pm    Post subject: Reply with quote
EXT 3D works plug 'n play with a Lumagen and 3D emitter.
ElTopo
Barco Cine 9 the one and only
noos@xp37+
PostLink    Posted: Wed Aug 05, 2015 4:43 pm    Post subject: Re: MOOME V3 ext 3D is not working... Still.... Reply with quote
Hello,
I had the absolute same problem - but changing the projector at the analog output solved the problem. From PC Nividia 3D Vision framepacked 3d I get an over and under 3D output at TAN Marquees from the moome card. But when I connect some Sony 12xx or a Sony HDIH - I get clean frame sequential 3d. This is from the same setup/video chain and hot swapping between projectors!
There is no technical explanation I can come up with, but for people with several display devices this will help.
Kind regards
Marc
