Rittberg Guest
Link Posted: Mon Sep 29, 2014 11:08 am Post subject: Barco 1209s - Convergence Output module R762519 |
Yesterday after switching on the PJ, the convergence and the geometry was absolutely distorted.
After checking all modules by my spare once I came to the tray contains the Convergence Driver & Output modules. With the spare tray the convergence and the geometry was perfect.
I switch between the Convergence Drivers modules in the two trays and the convergence was OK.
Switching between the Convergence output modules in the two trays the convergence become distorted with the old module and ok with the spare one.
Looking in to the Convergence output module, I find that the resistor “SR1” (page 271 in the manual) was damaged.
Should I just replace that resistor?
What can be the reason for blowing that resistor?
Thanks.
redfox001
Link Posted: Mon Sep 29, 2014 6:31 pm Post subject: |
Yep try it.
Link Posted: Mon Sep 29, 2014 8:20 pm Post subject: Re: Barco 1209s - Convergence Output module R762519 |
Rittberg wrote: | Should I just replace that resistor?
Probably the replacement resistor will blow too, the cause probably is a deffective convergence amplifier (output transistor).
cosaw
Joined: 08 Mar 2006 Posts: 159 Location: Nottingham, England
Link Posted: Tue Sep 30, 2014 1:36 pm Post subject: |
I agree with gjaky. If I'm remembering correctly: If it's a red resistor they're usually "safety resistors" and I think they're essentially fusible, i.e. supposed to act like fuses. The actual fault will be related but exist elsewhere in the circuit - probably close by.
Link Posted: Tue Sep 30, 2014 1:54 pm Post subject: |
I've got replacement boards if you need one.
redfox001
Link Posted: Tue Sep 30, 2014 3:06 pm Post subject: |
cosaw wrote: | I agree with gjaky. If I'm remembering correctly: If it's a red resistor they're usually "safety resistors" and I think they're essentially fusible, i.e. supposed to act like fuses. The actual fault will be related but exist elsewhere in the circuit - probably close by. |
Yes I agree too. Think it is a resistor in the collector line close to the power so it should directly connect to the bad mosfet.
Link Posted: Tue Sep 30, 2014 5:02 pm Post subject: |
I have had that happen right after I had reseated the convergence tray. I believe the tray was not properly located. After changing the board and seating the tray properly the problem did not reoccur.
Rittberg Guest
Link Posted: Tue Sep 30, 2014 6:59 pm Post subject: |
Update:
First - Thanks for your inputs,
Second – The PJ is back in operation with the repaired faulty board.
I take the faulty board to a TV repair shop, they checked and didn't find any other faulty component, so they decide to replace the resistor/fuse with another more sensitive one, for me it looks tinier in the diameter but with the same colors as the original one.
They decide to replace with the tinier one to prevent any damage to other parts in case it will happen again.
So I installed the repaired board and the PJ is running OK for more than 10 hours.
Thanks.
Barry
Joined: 01 Feb 2007 Posts: 186 Location: Los Gatos , Ca.
Link Posted: Mon Apr 06, 2015 8:29 pm Post subject: |
Rittberg wrote: | Update:
Thanks. |
I have a similar problem but the resistor bands ore not readable, likely heat an age.
Where did you get the replacements?
Values?
Barry
_________________ Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
Barry
Thanks. |
Values?
Barry
Hulio
Link Posted: Mon Apr 06, 2015 11:18 pm Post subject: |
Hello Barry,
Here a pic of SR1 from my BR909. Almost all Barco projectors ( from 700 to 909 series ) use the same value SR1 and SR2 fusible resistors on their convergence output modules. If i'm not wrong, they are 0,1 ohm, 10% tollerance ( brown, black, silver, silver, black ).
349.98 KB |
4879 Time(s) |
Barry
Link Posted: Mon Apr 06, 2015 11:38 pm Post subject: |
Hi Hulio,
Thanks for that...yes that is the one. I got different readings from different resistor charts on line. I was measuring very low resistance and .1 ohm could be why. I just need to search out fusible resistors. Perhaps I will settle for metal film as sufficient about .5W - .7W looks about right. I had 2 of the boards both go, both SR1 so cannabalized on from one board and got one working.
Barry
