bbassinger
Link Posted: Mon Sep 29, 2014 3:14 am Post subject: Vision One Foam |
I have been reading a lot about the Vision One/Marquee and it appears that the foam around the lenses serves as part of the cooling. I finally had a chance to take my Vision One hood off and there was no foam around the lenses. Is this not needed on the Vidikron? If it is needed, where can I get some foam?
the big E
Link Posted: Mon Sep 29, 2014 6:15 am Post subject: |
Mine had it with the marquee panels but the vidikron fiberglass case does not
I have the foam for a marquee 9500lc if you think it will work(don't need it now)
redfox001
Link Posted: Mon Sep 29, 2014 8:54 am Post subject: |
I think the foam is just there to keep the dust particles out.
Link Posted: Mon Sep 29, 2014 1:40 pm Post subject: |
I've never seen a Vision 1 with foam.
bbassinger
Link Posted: Mon Sep 29, 2014 11:30 pm Post subject: |
I guess I won't worry about it, then. Is it bad to run these with out the covers on? I want to do an extended test before sending the boards to draganm. Do I need to put the vision case back on to do that?
Link Posted: Mon Sep 29, 2014 11:36 pm Post subject: |
Nope, the covers don't really direct air flow, so you're fine.
bbassinger
Link Posted: Mon Sep 29, 2014 11:54 pm Post subject: |
Ok, The unit is in the garage, I'm going to hook up a Blu-ray to it and let it run a few hours. Anything I need to double check, or be weary of?
Link Posted: Tue Sep 30, 2014 12:16 am Post subject: |
Bleed the tubes! Mandatory for any Marquee.
