Link Posted: Sun Dec 07, 2014 8:20 pm Post subject: |
gjaky wrote: | Nashou66 wrote: | the TV one Resolution editor shows it at 118 mhz pixel clock.
it depends on the porch settings that the source device uses, TV-One must use a different method.
120 MHZ refresh shows a 150 mhz pixel clock for the same resolution.
But still low and why I like Blending.
Nashou |
Aren't the scanlines too visible at that resolution on the 9500s? Even at 720P scanlines are visible on a properly set up 8" machine, and that equals to 960 pixels in 4:3, you use smaller resolution on a larger tube. |
I don't see them, Gordon has seen the blend and so has Kurt. The only thing I don't like is the blend zone you can notice some times. If the movie is good and your into it you forget to look for it.
I have to get about 5 feet from the screen. The Higher refresh rate eliminates them. If I go to 60 hz i can see them, but at 72 or 96 i can't.
Melifluonze
TV/Projector: 9500LC Ultra
Link Posted: Mon Dec 08, 2014 6:00 pm Post subject: |
Even with the minimal blend zone issues (that you only see if you're really anal and have a history of tweaking stuff) Nash's blend set up is sick.
We took apart Return of the Jedi, checking focus on all the scenes of the movie because it was that crisp. Colors were awesome! Brightness was super! Jedi has some really poorly focused scenes in it!!!
I've got these new neck boards on two sets of brand new LUGs I have looking at me from the table... just don't know if I want to use the new tubes first, or store them with the boards on them for future use... Decisions...
I'm noticing that everything is in 2.35:1 now, so before I burn this pattern into my 16:9 projector, I've got to get the screen and dual projectors up for the blend... my next project...
Sorry... not trying to hijack... just wanted to say that the blend is awesome!
- M
_________________ Dual Marquee 9500LC Ultras, Dual JVC RS600
stridsvognen Guest
Link Posted: Sat Jan 31, 2015 9:49 pm Post subject: |
I just got 6 or 7 set of these new neckboards, and as it dont look like anyone else want to tell how they perform, ill soon be able to test them myself.
Link Posted: Sat Jan 31, 2015 10:46 pm Post subject: |
Ok Just popped mine into my test bed that isn't set up for anything than to just check bad boards so I can repair them.
Having said that they seems to have a cleaner back ground than stock board. Cant test anymore than this.
Also you have to use all three of the same boards in the PJ. The Blue and red did not light up with the
new style on the Green Tube. I put the old Green VNB on and all tubes light.
So that has been confirmed.
stridsvognen Guest
Link Posted: Sun Feb 01, 2015 1:19 am Post subject: |
It takes less than 5 min to trow in 3 neckboards and display a image on a screen. And a very very slow BD player might need a few min to load some test patterns.
stridsvognen Guest
Link Posted: Sun Feb 01, 2015 11:27 am Post subject: |
Nashou66 wrote: | Sorry my nephews birthday is more important . |
Dont worry, you had yours for so long ill never expect it to happen..
Link Posted: Sun Feb 01, 2015 11:34 am Post subject: |
Why is this b!tching Kurt, you said you'll do the test, then do it There is a posibbility even if Nashou does the test you'll be skeptic... The only good test is what one do for oneself.
stridsvognen Guest
Link Posted: Sun Feb 01, 2015 11:49 am Post subject: |
gjaky wrote: | Why is this b!tching Kurt, you said you'll do the test, then do it There is a posibbility even if Nashou does the test you'll be skeptic... The only good test is what one do for oneself. |
Easy now im just teasing those guys a bit.. They have been flashing these new boards for the longest..
Ill test them, but ill not bother anyone on this site with my useless tests.. ill let others do that. Just think it would be nice that some of the guys who know more about CRT than i do, do some serious testing like bandwidth gamma noise and so on.
This thread only have pics of the boards. And it wont help anyone with the option to buy a set of those neckboards deciding if its a good deal or not.
Link Posted: Sun Feb 01, 2015 12:14 pm Post subject: |
I am planning to put Marquee VNBs in my NEC XG, instead of the original neckboards, those are hard to find and expensive. I have to make an auxiliary power supply for it to mate with the XG. Once I have the power supply done I'll test the stock marquee neckboards I already have here with my 500MHz FET probe and HP 1720A scope. With that we are not just get screenshots of testpatterns but actual numbers on rise and fall times.
stridsvognen Guest
Link Posted: Sun Feb 01, 2015 12:45 pm Post subject: |
gjaky wrote: | I am planning to put Marquee VNBs in my NEC XG, instead of the original neckboards, those are hard to find and expensive. I have to make an auxiliary power supply for it to mate with the XG. Once I have the power supply done I'll test the stock marquee neckboards I already have here with my 500MHz FET probe and HP 1720A scope. With that we are not just get screenshots of testpatterns but actual numbers on rise and fall times. |
That just dont do much for these new type boards, and this thread.
Link Posted: Sun Feb 01, 2015 12:52 pm Post subject: |
Once I have the power supply, that will allow me to MEASURE any VNB on the bench, let it be the new style VNB, or a super-mighty-über-modded Mike Parker VNB, or just a plain original VNB. To my knowledge all of these operate from the same supply lines...
Sorry that I bothered with unneccesary informations
dvh99
Link Posted: Sun Feb 01, 2015 1:55 pm Post subject: |
looking forward to your results gjaky.
maybe you can play with some different inductor values on the vnb.
Link Posted: Sun Feb 01, 2015 2:01 pm Post subject: |
stridsvognen wrote: | gjaky wrote: | I am planning to put Marquee VNBs in my NEC XG, instead of the original neckboards, those are hard to find and expensive. I have to make an auxiliary power supply for it to mate with the XG. Once I have the power supply done I'll test the stock marquee neckboards I already have here with my 500MHz FET probe and HP 1720A scope. With that we are not just get screenshots of testpatterns but actual numbers on rise and fall times. |
That just dont do much for these new type boards, and this thread. |
What are you going to feed into the input of the neck boards for this testing?
stridsvognen Guest
Link Posted: Sun Feb 01, 2015 2:26 pm Post subject: |
mp20748 wrote: | stridsvognen wrote: | gjaky wrote: | I am planning to put Marquee VNBs in my NEC XG, instead of the original neckboards, those are hard to find and expensive. I have to make an auxiliary power supply for it to mate with the XG. Once I have the power supply done I'll test the stock marquee neckboards I already have here with my 500MHz FET probe and HP 1720A scope. With that we are not just get screenshots of testpatterns but actual numbers on rise and fall times. |
What are you going to feed into the input of the neck boards for this testing? |
I can feed them direct from the moome card, or from different VIM, with different sources like HDMI from BD players or RGBHV frompattern generator.
Link Posted: Sun Feb 01, 2015 2:31 pm Post subject: |
My question was to gjaky. He spoke of getting a power supply to test a marquee neck board, and besides going to need three dual supplies (+/- 85, +/- 14, +/- 5) he's also going to need to feed the neck board. My question is what do he intend to use
Link Posted: Sun Feb 01, 2015 2:45 pm Post subject: |
mp20748 wrote: | My question was to gjaky. He spoke of getting a power supply to test a marquee neck board, and besides going to need three dual supplies (+/- 85, +/- 14, +/- 5) he's also going to need to feed the neck board. My question is what do he intend to use |
I used my VGA card's RGB output to test the XG neckboards, so I guess it will do for the VNBs too.
Link Posted: Sun Feb 01, 2015 4:58 pm Post subject: |
Yes it will
