Link Posted: Thu Aug 28, 2014 4:47 pm Post subject: Ok, NEC GP5000 questions... |
I know, I know these beasts are from the stone age, but let's go on...
So found this: http://kleinanzeigen.ebay.de/anzeigen/s-anzeige/roehren-projektor-nec/197676969-175-1966?ref=search
A contact has been already made with the seller, he know little about the machine but he swears he bought it as a NEC 9 PG + from a professional company, a trained eye should see however this is a 9" machine, but it is not quite looking like a 10PG, so it is probably a GP5000...
Let's forget the asking price for a moment, and follow me.
I am planning on doing one real, genuine 9" PG xtra (to replace my unwholesome XGLC) -with every features included. This would need a 10PG chassis (obviously). The GP5000 seemingly have everything what I need for this as well, (9" tubes and a matching box).
But what about those tubes, they are said to be very dim, and have little fact about it's focusing capability.
The light output of the tube is usually matter of how hard it is pushed, now as I plan putting in every board from a PG xtra (incl. HVPS) so the light output is probably out of question somewhat.
Still can't decide if the said softness of these machines are coming from the tube construction directly or simply the inferior electronic circuits.
Curt, anyone?
Link Posted: Fri Aug 29, 2014 12:06 am Post subject: |
What are you going to do about neck boards?
Link Posted: Fri Aug 29, 2014 12:08 am Post subject: |
That certainly looks like a 10PG to me Gábor... I wouldnt like to be sure though cause the pics are not good angles...
Link Posted: Fri Aug 29, 2014 12:58 am Post subject: |
Sure looks like a PG+ to me.
Zolzar
Link Posted: Fri Aug 29, 2014 1:02 am Post subject: |
I'm pretty sure that's is indeed a GP5000. The case sure looks like a PG10 but the limited observable layout seems to dictate otherwise. I don't see any of the boards below the green tube such as the focus board that the PG10 has. Also is appears that the green the is actually under a hinged board in one of the pictures. Again, the PG10 green is not obstructed by any hinged boards. The only tube in a PG10 that is obstructed is the red. Lastly I don't see the card cage with the system and point boards between the blue and green that are present in the PG10.
The GP5000 was the last air coupled 9" projector made by NEC and unfortunately had a reputation for projecting a very soft dim image.
John
Link Posted: Fri Aug 29, 2014 1:09 am Post subject: |
That's true. I retract my first thought.
Link Posted: Fri Aug 29, 2014 3:33 am Post subject: |
That was exactly what made me unsure, what i could see of the pic i couldnt tell well enough what was where, but that HV splitter is totally different.
Link Posted: Fri Aug 29, 2014 3:43 am Post subject: |
Wasnt it LC?
Link Posted: Fri Aug 29, 2014 6:15 am Post subject: |
It has HD10 lenses so it must be LC, and looks like it has at least a nice red and green c-element. So I have to buy it at a price, if it turns out to be no go, then selling out the c-elements would save me from loosing money... The seller have no taker since march, so he may want to lower the price
As for the neckboards, I figured out that the PG xtra neckboard actually designed to fit on large necks too as far the pcb is concerned, they used a tapered CRT socket to use them on the small tubes, so I just have to swap the socket with the one that is already in the machine, of course might have to rewire but, no mechanical problem with that as far as I can see.
Link Posted: Fri Aug 29, 2014 7:36 am Post subject: |
Should be a goer then, i dont know if Evan still has those 9" NEC tubes or not, they would be better tubes for the job.
Link Posted: Fri Aug 29, 2014 7:19 pm Post subject: |
I've read on the other forum, years back someone ran his GP5000 at 1800x1200, but no pictures unfortunately... I remember A_Rogers put GP3000 tubes in a PG xtra just for fun, and he said it was sharp, again no pictures unfortunately...
Link Posted: Sat Aug 30, 2014 2:41 am Post subject: |
It will probably be as much the set driving the tubes as it is the tubes themselves...
