Link Posted: Sun Aug 17, 2014 2:31 am Post subject: MUX-HD V1 color question |
Found one of these when I was cleaning up over here so I decided to try it with a Samsung DTB-H260F into my RPTV at 1080i.
For the most part the picture is Black and White BUT- RED comes through. Making everything look like one of those black and white photos with the roses colored in. Kinda cool but it made for an interesting episode of CSI
I have the remote but not the manual. IS there a way to manually change the color space on this?
Signal chain is:
H260F--HDMI.cable---->MUX-HD---DVI.to.DVI.cable--->TV
Link Posted: Sun Aug 17, 2014 6:28 am Post subject: |
OK just did a little testing....
The MUX-HD works OK with the SONY S550 Bluray player regardless of selected color space. 4:2:2, 4:4:4, RGB 16-235, & RGB 0-255
Wonder why the Samsung box won't display properly? I previously had it running into an HDFury1 to an IFB-12 card in the 1270 switch and out to the SONY D50. Color was perfect. Hmmmm????????
moome
Link Posted: Sun Aug 17, 2014 3:42 pm Post subject: |
AnalogRocks wrote: | OK just did a little testing....
Wonder why the Samsung box won't display properly? I previously had it running into an HDFury1 to an IFB-12 card in the 1270 switch and out to the SONY D50. Color was perfect. Hmmmm???????? |
hi, try to press remote C or D.
Download |
Filename: |
mux_hd_v13.pdf |
326.53 KB |
Downloaded: |
537 Time(s) |
Link Posted: Mon Aug 18, 2014 3:52 am Post subject: |
Hi Moome,
Pressing C or D did not fix the color.
moome
Link Posted: Mon Aug 18, 2014 1:13 pm Post subject: |
AnalogRocks wrote: | Hi Moome,
Pressing C or D did not fix the color. |
oh, yes, C & D are to select output mode.
MUX-HD can not manual select the input color space.
the mux-hd may get incorrect Avi info, so MUX-HD can not know which color space to select.
then you will need MUX-FHD.
Best Regards
