Meter correction
yoko
PostLink    Posted: Sat Aug 16, 2014 10:23 pm    Post subject: Meter correction Reply with quote
Hello
i have a question with chromapure meter Correction button
better to enable this option? it's for Idisplay pro or standard ? or both are good to enable this option
because all settings are 0
if i understand field meter = Idisplay meter
and reference meter is other material ? if i don't have a reference meter , this is possible to use the meter correction?
thank you
PostLink    Posted: Sun Aug 17, 2014 1:47 pm    Post subject: Reply with quote
ChromaPure has the option of correcting a meter's performance (called a 'field' meter) with a reference device (the reference meter).
See the section here called "why buy two meters?" for more explanation as to why you'd do this:
http://www.curtpalme.com/forum/viewtopic.php?t=11436
yoko
PostLink    Posted: Sun Aug 17, 2014 2:55 pm    Post subject: Reply with quote
ok do you think it 's possible to have a better autocal with EyeOne Display 3 meter ,video projector JVC RS49 and lumagen radiance 9x9x9 calibration device
i'm not a specialist but here my adjustment:
4K eshift disable
preset : natural
6500K
all in RGB Level video (chromapure/VP/Scaler)
Advanced Color Gamut :2
Reference Gamut Rec 709 / dE Methode CIE94
Gamma method 2,2
Matrix size 729 points
Measure post calibration 125-729 colors
oppo is OFF
meter : front projector screen
i disable all corrections with scaler lumagen /video projector
i launch directly auto cal and when it"s finish, i adjust contrast and luminosity with lumagen pattern
here the result: i can't have a better CIE specially for green, other post colors are not perfect with reference color.
i forgot a step?
after autocal do you adjust Advanced Colormanagement or normally you don't have to change any color??
thank you in advance
 Filesize:  73.09 KB
 Viewed:  3972 Time(s)
 Filesize:  146.52 KB
TomHuffman
PostLink    Posted: Mon Aug 18, 2014 2:30 am    Post subject: Reply with quote
4K eshift disable
preset : natural
6500K
Gamma method 2,2
oppo is OFF
i forgot a step?
Please send a full calibration report and copy/paste the data in the activity window into a text file and send that too.
Send to support@chromapure.com
To diagnose the problem I need more information.
- Tom Huffman
