Building a Home Theater & Listening Room
hydrovac
PostLink    Posted: Mon Aug 04, 2014 6:38 am    Post subject: Building a Home Theater & Listening Room Reply with quote
Hi all,
My wife finally parted with a portion of her terrace garden and let me build a home theater.
First off all I find myself very fortunate to build a room that can be dedicated to music listening and watching movies. The room will be 3.96 meters wide, 7.38 meters long and a height of 2.7 meters. So with a little more than 29 m2 it's not a big room at all.
We live in a duplex penthouse (5th & 6th floors with terrace rights). So, traditional construction methods are a bit difficult. I plan to take the prefab route.
Proposed HT Room area.
Columns set and trusses on.
jeffslife
PostLink    Posted: Mon Aug 04, 2014 12:42 pm    Post subject: Reply with quote
cool !
We are ALL job creators !
hydrovac
PostLink    Posted: Wed Aug 06, 2014 9:50 am    Post subject: Reply with quote
Thanks jeffslife,
The progress in construction of prefab wall panels:
Rear wall panels:
Screen wall panels:
PostLink    Posted: Wed Aug 06, 2014 2:33 pm    Post subject: Reply with quote
Looking good.
Since you have a concrete floor, you may want to put down a rubber underlayment.
Have you bought your equipment?
hydrovac
PostLink    Posted: Thu Aug 07, 2014 5:52 am    Post subject: Reply with quote
Thanks Spanky Ham,
I am planning for a thick wall to wall carpet... How does putting down a rubber underlayment help? I am piling up equipment...its going to be a mix of old and new gear. I am starting with DIY amps, a new Sherbourn PT-7020A , used speakers, existing projector and a big screen. As time goes by, and as my finances improve, I will slowly replace my components. I chose not to design a contemporary style theater. I wanted my home theater to remain true to my great memories of a traditional movie theater.
PostLink    Posted: Thu Aug 07, 2014 1:35 pm    Post subject: Reply with quote
http://www.soundproofingcompany.com/soundproofing-articles/flooring-protecting-a-concrete-slab/
I was planning on using rubber, but I may just go with cork because it is cheaper and local.
Not sure what your budget is, but you may want to look at Dolby Atmos for your sound setup. Since you are on this site, I am guessing that you are going with a CRT for the pj.
hydrovac
PostLink    Posted: Thu Aug 07, 2014 4:49 pm    Post subject: Reply with quote
I am looking at JBL speakers and I have an Epson projector.
These pics are of the composite decking sheet being fixed.... in fact yesterday...the plasterers were skimming the walls and pouring the concrete slab....
I will add more photos as the work progress.
PostLink    Posted: Thu Aug 07, 2014 5:36 pm    Post subject: Reply with quote
Cool project. It's fun to see how different countries' and regions' residential building practices differ. The prefab panels are more often found in commercial or heavy construction here, and typically larger. That makes me wonder (because I can't tell from the photos)... How tall is the building your place is in, or more to the point, what floor do you live on?
Are you going to leave the trusses exposed? They're kind of neat. It looks like they were recycled. Very cool.
Atmos, Spanky? Seriously? A few months ago, you're basically saying you don't really care about audio, and now you're talking about Atmos? Wink
hydrovac
PostLink    Posted: Fri Aug 08, 2014 2:18 am    Post subject: Reply with quote
Thanks ecrabb,
Keen observation and rightly pointed out! The trusses were salvaged from an existing structure, which was in front of my 5th floor duplex penthouse supporting a shade.
I have built a new structure and converted it into a sky deck and usable space. You can see the old structure below the new one.
The old trusses are shifted to 6th floor to support the composite slab of my HT. So load bearing is not an issue.
Old structure removed
Sky deck finished and ready for use.
PostLink    Posted: Fri Aug 08, 2014 2:55 am    Post subject: Reply with quote
Which JBL speakers are you looking at?
THANKS TO YOU!! Twisted Evil
Admittedly, I have a price point that I don't think I would go above. With Atmos, I may push that price upwards slightly. Until I read about it coming to the home, I wasn't that interested in audio. Now, I want to hear it for myself at some trade show that is only a couple of weeks away. Wink If it is a game changer, then I will look to incorporate it with the upward firing speakers.
Jeremy112
PostLink    Posted: Fri Aug 08, 2014 4:43 am    Post subject: Reply with quote
Hydrovac, I am very impressed! Not only with how awesome your new room is turning out, but the mere speed you are making it happen (I assume from what I have read and seen that you are doing this as you post these pics to the site?)
Either way, I am fascinated and I am quite interested to see how your theater turns out. Keep up the good work Thumbs Up
hydrovac
PostLink    Posted: Fri Aug 08, 2014 3:17 pm    Post subject: Reply with quote
Thanks Jeremy112,
Started laying electrical, speaker and signal cables. The cabling work is being carried out by a local guy and someone from my work giving him a hand.
To reduce hum and noise I want to install a dedicated line with only a single ground from the audio / home theater system to the electrical service panel. Don’t want to attach anything other than the A/ V system to this special dedicated line.
Expecting the result to be noise and hum free power with a 'deep black background'.
By this stage of the project, I have already identified the following :
• Placement of all speakers
• Placement of A/V components
• Placement of video source
• Lighting needs
• Possible future enhancements
• Thermal Insulation & Acoustic Treatment
BTW I have provided a frame also…for supporting the screen.
I will try and post pics if there's interest...as soon as i work out how to do it....!!
I have all the kit i need already for this…mix of new and from old lounge... not top end by any means...but works for me...
HT room outside from terrace.
hydrovac
PostLink    Posted: Sun Aug 10, 2014 1:15 am    Post subject: Reply with quote
Framing work in progress for rock wool slabs…
Checking out my old screen…
16:9 screen pulled down…
PostLink    Posted: Sun Aug 10, 2014 1:40 am    Post subject: Reply with quote
Very nice! Love the way it's coming together.
hydrovac
PostLink    Posted: Sun Aug 10, 2014 4:38 pm    Post subject: Reply with quote
Thanks AnalogRocks,
Framing work completed and AV cabinet in place….cabling almost done but for one sub signal cable. Got 20 Rock wool bags delivered yesterday.
There was a leak from one point of the slab joint side…. getting the pressure grouting done today.
Entry door to the theater on the left:
Bags containing Rock wool slabs:
AV cabinet built into the window:
Ceiling panels getting ready:
Insulation panels being fixed:
Ceiling Panels fixing:
hydrovac
PostLink    Posted: Thu Aug 14, 2014 5:38 pm    Post subject: Reply with quote
Paneling of rock wool frames almost done:
Steel trusses being enclosed in wooden beams:
PostLink    Posted: Fri Aug 15, 2014 2:06 am    Post subject: Reply with quote
Very very Nice!!!
For Clean power look into installing a large enough Isolation Transformer between your main service panel and the theaters sub panel. I bet a 5-8kva transformer should do. It will act as a dedicated power source for your sub panel and Isolate the ground from the rest of the house and power company. Not sure what the laws are in india for that tho.
hydrovac
PostLink    Posted: Fri Aug 22, 2014 1:19 pm    Post subject: Reply with quote
Thanks for the suggestion,
Further on construction:
Back row riser in place:
Front row riser:
hydrovac
PostLink    Posted: Sat Aug 23, 2014 6:25 pm    Post subject: Reply with quote
Got few sample seats today... my folks liked the red one, the design part of it and not the fabric though. Actually it is wider by 2” and comfortable than the other two.
Decided to order seven seats with individual arm rests… and different cloth material which I have to select.
hydrovac
PostLink    Posted: Sun Sep 28, 2014 3:11 am    Post subject: Reply with quote
Slow progress, but progress nonetheless. Tough to get things done when you are on carpenter’s schedule, but I'm grinding along. Got most of the ceiling done, preparing bass traps and acoustic panels…
