jeffslife
Link Posted: Sat Jun 21, 2014 6:51 pm Post subject: I have a line |
I noticed watching Fargo on DISH that I had a "line" where my 2.40 aspect ratio would normally be.But just on the top part. The image above the line is brighter than the image below. The image below has a kind of pinkish tint. Its very slight but I notice it. I thought it was just an issue with Dish but was watching a 1.85 AR movie last nite and there it was again. Granted I am probably the only one who notices it and it is only noticeable it bright scenes but it bugs me. Any ideas ?
Link Posted: Sat Jun 21, 2014 7:36 pm Post subject: |
Say Jeff
Put up white field from another source, see if you have any tube wear creeping in
Link Posted: Sat Jun 21, 2014 7:51 pm Post subject: |
It's tube wear.
Link Posted: Sat Jun 21, 2014 10:06 pm Post subject: |
It's the pixel fairy messing with you.
jeffslife
Link Posted: Sat Jun 21, 2014 10:41 pm Post subject: |
Ok so if its tube wear what can I do ?
Link Posted: Sat Jun 21, 2014 10:55 pm Post subject: |
Nothing, short of replacing the green tube.
Link Posted: Sat Jun 21, 2014 11:00 pm Post subject: |
Wear level it.
jeffslife
Link Posted: Sun Jun 22, 2014 12:06 am Post subject: |
Casey. ?
Link Posted: Sun Jun 22, 2014 12:54 am Post subject: |
Sorry mate ill find you the link
Link Posted: Sun Jun 22, 2014 12:57 am Post subject: |
http://www.curtpalme.com/Balancing_CRT_wear.shtm
Should be really easy because youve only got to do a less used section of the screen.
jeffslife
Link Posted: Sun Jun 22, 2014 2:48 pm Post subject: |
I had no idea that was possible. Someone told me once that the white warm up screen (that everyone says to turn off) is there to stop this problem to some extent. I have no idea and it really doesn't matter at this point. I don't have the computer, software or skills necessary to fix this problem so I guess I will just learn to live with it for now, until I install new tubes or go digital. Probably the latter though not looking forward to it.
Link Posted: Sun Jun 22, 2014 3:11 pm Post subject: |
Jeff,
Curt has some new tubes for good prices. You could have Craig out to install them for you.
jeffslife
Link Posted: Sun Jun 22, 2014 3:27 pm Post subject: |
I have a set of tubes. I was hoping to get some more life out of these. It really isn't bad yet and if I watch 2.4 AR which is 90% of what I watch I have no issue at all. I was kinda hoping I wouldn't have to ask craig to come all the way out here till I either got a radiance or a new PJ or both. Although it would be nice to hang out again.
Link Posted: Sun Jun 22, 2014 3:44 pm Post subject: |
Hey Jeff,
Because 2.35 is 90% of what you watch, you are getting uneven wear between 2.35 and 1.78. You have several options to either slow the progression or even reverse the uneven wear. If you keep doing what you are doing than the line will only get darker. Your tubes are not wearing out prematurely, they are just wearing unevenly because you watch so much more 2.35 tan 1.78.
Since you use the Lumagen HDQ runnin 817p 2.35 at 72Hz, the simplest and most effective remedy would be to reposition the image for 2.35 on the face of the G90 tube. I would suggest moving the image for 2.35 up on the screen, and across the line by about 2" from where it is now. To do this, just use the "center" adjustment for green, then red, then blue. Move the image up and then adjust your masking system for the new positions. Be sure to do this in the G90 only for the 2.35 memory with the Lumagen running.
After some months, or between 500-1000 hours, move the 2.35 image down about 4" to below (2" below the original line) where the original line is. As the tubes age the line will have migrated and the burn in will become less noticeable or disappear. The earlier you catch this and make the change the less time it will take for the burn in line to reduce or disappear.
Another option is to watch 2.35 with 1080p trough the Lumagen (on memory A) which is 1080p 60Hz for you. You can then zoom the image with the Lumagen by 5% to push the image past the burned in line. This will eventually start to wear level the tubes. I don't like the zoom technique though because it forces all material to be scaled and overscanned. You will loose image front he sides as well because you are zooming it off the pixel map.
Link Posted: Sun Jun 22, 2014 11:19 pm Post subject: |
jeffslife wrote: | I had no idea that was possible. Someone told me once that the white warm up screen (that everyone says to turn off) is there to stop this problem to some extent. I have no idea and it really doesn't matter at this point. I don't have the computer, software or skills necessary to fix this problem so I guess I will just learn to live with it for now, until I install new tubes or go digital. Probably the latter though not looking forward to it. |
Get someone to do it for you and put it on a DVD, then all you need to do is play that disc and move the image up or down on your screen to suit where it needs to be.
jeffslife
Link Posted: Wed Jul 30, 2014 4:20 pm Post subject: |
Does the white warm up screen wear level the tubes ? Is that the entire purpose of it ? If so does it burn through phosphor at a much faster rate ? Just curious.
Link Posted: Thu Jul 31, 2014 1:55 am Post subject: |
Nope, it warms up the machine quicker.
jeffslife
Link Posted: Wed Sep 24, 2014 9:10 pm Post subject: |
So I did what Craig suggested and adjusted my masking and moved the 2.35 image up 2" above where the wear line was. I am running 817P @ 72 hz out of the lumagen HDQ on memory B. After moving the image I adjusted the center and then spent an hour dialing in zone. The image is great except for one problem. The B image is darker and has less shadow detail, a lot less. To get close to what it looks like on 1080P 60 hz I would have to increase the brightness by 8 running it at about 63. Any ideas ?
UncleWill
Joined: 11 Dec 2012 Posts: 413 Location: WashDC area, ViennaVA
Link Posted: Fri Sep 26, 2014 3:11 am Post subject: |
I have some wear on the right side of my tubes. Shifting the raster slightly away from the wear line helped me notice it less.
jeffslife
Link Posted: Sun Nov 16, 2014 5:19 pm Post subject: |
Ok so in order to watch the 2.35 AR 817 @ 72 hz I have to have the brightness set at 70. Then it looks the same as 1080P @ 60 hz when the brightness is set at 55. So how fast is this high brightness setting burning up my tubes ? The 72 hz setting looks amazing in brighter scenes but still doesn't look as good as 1080p 60 in darker scenes, even with the brightness set at 70. Is there any way to COPY the 1080P 60 settings to the 2.35 AR and still leave the position 2 inches above "the line" ? My wife even asks "whats wrong" when we watch 2.35 now.
