Vcr lines
larryp
PostLink    Posted: Wed Feb 19, 2014 4:34 pm    Post subject: Vcr lines Reply with quote
I just hooked up my JVC HR-S9911U vcr to my Direct tv box. Everything works ok, but when I have the vcr on there is a white horizontal line that floats upwards on the picture. Not real noticeable, but there. It's not there when using just the direct tv box. It shows up when recording to
I'm guessing it's something to do with the vcr tuner ??
Not a big deal, but wondering if some type of filter might be available to get rid of it??
zaphod
PostLink    Posted: Wed Feb 19, 2014 4:44 pm    Post subject: Reply with quote
sounds like a "hum bar", which can be caused by a ground loop issue, often with the cable feed to the house being poorly grounded.
larryp
PostLink    Posted: Wed Feb 19, 2014 4:46 pm    Post subject: Reply with quote
Thanks, I'll check the ground connections
PostLink    Posted: Wed Feb 19, 2014 4:49 pm    Post subject: Reply with quote
Also try plugging your VCR into the same AC outlet as the direct TV box if you haven't already done so.
PostLink    Posted: Wed Feb 19, 2014 4:52 pm    Post subject: Reply with quote
Do you have cablevision connected to the VCR? If so, disconnect it and see if the line goes away.
larryp
PostLink    Posted: Wed Feb 19, 2014 7:52 pm    Post subject: Reply with quote
What is cable vision? All I have connected is the Direct tv box
I'll check that both items are plugged in the same strip.
PostLink    Posted: Wed Feb 19, 2014 8:23 pm    Post subject: Reply with quote
OK, same thing. Disconnect all incoming signals to the VCR, so that only the output is connected.
larryp
PostLink    Posted: Thu Feb 20, 2014 12:17 am    Post subject: Reply with quote
Unhooked the direct tv. Screen is blue set on L 1- Lines show up really well. Moving fast up the screen to.
Can anything be done to get rid of them?
Plugged the sat box & vcr on the same outlet strip. No difference
PostLink    Posted: Thu Feb 20, 2014 12:24 am    Post subject: Reply with quote
I have that issue here if I run a video line from one side of my living room to the other. I got around this by plugging all video and audio equipment into the same side of the AC line. That is. All the outlets come out off the same side of your fuse/breaker panel.
You could cheat and use an extension cord on just the VCR.
larryp
PostLink    Posted: Thu Feb 20, 2014 1:56 am    Post subject: Reply with quote
I use 2 outlet strips, both are plugged into the same outlet. no difference.
what cause the lines?
PostLink    Posted: Thu Feb 20, 2014 2:05 am    Post subject: Reply with quote
It could be a bad VCR? Can you try another one? What happens if you disconnect the audio lines from the VCR, and the only thing you hvae connected is the video output?
larryp
PostLink    Posted: Thu Feb 20, 2014 2:15 am    Post subject: Reply with quote
Unplugging audio made no difference. Only vcr I have. Everything else on it works great.
It's not that big of deal, mostly see the lines if it's a real dark scene. And even then they are not that noticeable.
I'll live with it.
PostLink    Posted: Thu Feb 20, 2014 2:21 am    Post subject: Reply with quote
it is a ground loop as stated above. It doesn't really make sense that it's the only source with an issue if you have nothing else connected to it. If you can beg or borrow another VCR, that would be the next step.
Cheers!
PostLink    Posted: Thu Feb 20, 2014 2:32 am    Post subject: Reply with quote
The lines are caused by a ground loop, I use to get it when I ran my TV cable into a tuner then into my projector. If you have a multi-meter put it across the outside of the coaxial or RCA connection on the VCR and the outside barrel of the satelite co-ax. Set the meter to AC and see what you get. In our old office I had 110 volts from the back of the PC to the TV cable.
http://en.wikipedia.org/wiki/Ground_loop_(electricity)
PostLink    Posted: Thu Feb 20, 2014 2:42 am    Post subject: Reply with quote
Are the TV and VCR AC plugs 2 prong or 3 and are they polarized?
larryp
PostLink    Posted: Thu Feb 20, 2014 2:43 am    Post subject: Reply with quote
My Video game, Roku player and dvd player and direct tv picture don't have any line problems. I don't know. If it was real annoying I'd look into it more, but as I say it's not real bad when watching direct tv thru the vcr/recording. I thought I'd ask thinking it might be a easy fix. Adding A Filter or something like that
Cheers!
larryp
PostLink    Posted: Thu Feb 20, 2014 2:47 am    Post subject: Reply with quote
The projector is 3 prong, It's plugged in separately.
The vcr is 2 pronged and plugged into a 3 prong extension strip
PostLink    Posted: Thu Feb 20, 2014 2:49 am    Post subject: Reply with quote
Is the VCR plug polarized?
PostLink    Posted: Thu Feb 20, 2014 4:02 am    Post subject: Reply with quote
One blade of the AC plug wider than the other.
larryp
PostLink    Posted: Thu Feb 20, 2014 5:10 am    Post subject: Reply with quote
yes it is
