zxh398
Joined: 05 Nov 2009 Posts: 55 Location: china guangzhou
Link Posted: Mon Sep 23, 2013 3:31 am Post subject: Barco S of small Modification a qualitative change in focus |
Barco 808S 1208S 1209S video channels are known 180MHZ bandwidth with 909 identical, differing only in CRT socket difference. In fact, the transformation socket can get the same video bandwidth of 909 directly to obtain excellent focusing screen.
CRT socket difference is the use of IC S series socket is that the use of LC 80MHZ VPH08 nominal frequency compensation method is difficult to obtain a flat 120MHZ Bandwidth, 909socket model of IC is unknown and can not be purchased. My internal circuit transformation according VPH06 bandwidth constraints transistor, get 909 plate same bandwidth results.
This circuit is very common for CRT socket NEC PG EHome is the same, and the circuit is to replace higher bandwidth without changing the transistor. vph08 inside the IC is empty, just around the saw with a saw four complete separation 3MM depth can be obtained inside cover. I used 400MHZ bandwidth 2SA1406 C3600 replacement IC internal power output three tubes TR3.4, of course, put the original three complete discharge tube wiring can not have contact. IC's R4 must consider external 5W power, my final solution is still to use VPH08 external current limiting resistor. 200V voltage will be great because the heat can not use VPH internal resistance, but only VPH06 external VPH08 itself is built. With VPH06 is because some Barco CRT socket is VPJ08 is plastic can not be modified and can only be removed VPJ08 replaced VPH06 transformation.
I try to transform the IC is VPH25 18 15 VPA13, found inside the IC TR2 is different. TR2 of the pressure can not meet the needs of the input voltage 200V ic, VPH06 VPH08 withstand voltage of TR2 higher bandwidth is low. This effect is good enough
VPH series IC internal structure |
230 KB |
19521 Time(s) |
Polished sides of the modified placement of the IC transistor |
218.95 KB |
19521 Time(s) |
IC does not require the installation is complete closed |
250.86 KB |
19522 Time(s) |
Borrow 909 CRT socket pictures |
34.97 KB |
19525 Time(s) |
_________________ zxh1353@hotmail.com
zxh398
Link Posted: Mon Sep 23, 2013 3:47 am Post subject: |
VPH internal Drawings
45.18 KB |
19520 Time(s) |
zxh398
Link Posted: Mon Sep 23, 2013 5:33 am Post subject: |
Finally after the transformation of image effects, 808S circuit P19LCP07 HD10GT17 this character has been unprecedented clarity. I saw the sharpest CRT Projector, Modified Green can see the scan lines, unmodified Barco 1209S is impossible to observe I've been using nominal 150MHZ bandwidth XG1352LC, the effect was not as good display characters tailgate after this transformation Barco
Shoot digital camera card Samsung tl34hd night mode conversion as a relatively clear shot to the loss of 30% of the actual
132.93 KB |
19500 Time(s) |
The text effects WIN7 Desktop XG1352LC |
147.22 KB |
19500 Time(s) |
Download |
Filename: |
SDC10401.JPG |
227.64 KB |
Downloaded: |
856 Time(s) |
Download |
Filename: |
SDC10429.JPG |
235.2 KB |
Downloaded: |
810 Time(s) |
Download |
Filename: |
SDC10424.JPG |
256.27 KB |
Downloaded: |
847 Time(s) |
Observed near the screen to the scan line, the camera shooting distortion effects |
Download |
Filename: |
SDC10412.JPG |
253.21 KB |
Downloaded: |
860 Time(s) |
kabuby77
Link Posted: Mon Sep 23, 2013 8:30 am Post subject: |
Hi I'm interested, but I had hard times with "english"
fragzero
Link Posted: Mon Sep 23, 2013 8:57 am Post subject: |
I only have 1 word for this, AMAZING!
Do you have any more information about this? I'm very interested in this mod! Maybe you offer these mods?
zxh398
Link Posted: Mon Sep 23, 2013 8:59 am Post subject: |
sorry English is not good, google translate too bad
This means that if Barco replace the VPH08 IC transistor within the focusing improved significantly
fragzero
Link Posted: Mon Sep 23, 2013 9:08 am Post subject: |
Do you consider selling these mods? This would be an excellent upgrade for everyone with lower resolution Barco's!
If not, maybe you can provide us with more detailed information about this mod, i'm sure a lot of people here might be interrested in the DIY approach!
zxh398
Link Posted: Mon Sep 23, 2013 10:12 am Post subject: |
Transistor ebay easy to find . had no plans to sell Modify the IC making this process will not be difficult I will try to answer
Link Posted: Mon Sep 23, 2013 12:41 pm Post subject: |
ZXH you do some wonderful work from everything i see here. Very well done
kabuby77
Link Posted: Mon Sep 23, 2013 12:56 pm Post subject: |
VPA25H is hard to find, I have some VPA18. Can you explain your modification one more time
Decibel
Link Posted: Mon Sep 23, 2013 4:25 pm Post subject: |
Some questions for knowledge: you have pulled VPH08 and replaced it with modified VPH06, is right?
But I see that you have removed two of the three big resistors (white) from PCB. Is right?
_________________ Domenico (Barco fan!)
ElTopo
Link Posted: Mon Sep 23, 2013 5:17 pm Post subject: |
I had P16LNP's in my old Barco.
These were razor sharp witout any mods and 1080p looked great.
Link Posted: Mon Sep 23, 2013 11:55 pm Post subject: |
Got some shots Eltopo?
zxh398
Link Posted: Tue Sep 24, 2013 12:32 am Post subject: |
Modified pointless old Barco must electromagnetic focus, I've tried to modify VPA18 15 13 can work only VPH08 06
zxh398
Link Posted: Tue Sep 24, 2013 12:40 am Post subject: |
CasetheCorvetteman wrote: | ZXH you do some wonderful work from everything i see here. Very well done |
Yes, three big resistors (white), because 06.08 R4 using different values. VPH06 R4 is best to modify the built-in external 5W power resistors
ElTopo
Link Posted: Tue Sep 24, 2013 5:51 pm Post subject: |
Unfortunately have no shots of the old setup.
Additional to the P16 i used HD-145 with plates. It was a huge step up vs. HD-8.
zxh398
Link Posted: Wed Sep 25, 2013 12:29 am Post subject: |
Not changed CRTsocket Barco even if the replacement of HD145 focusing ability compared to other Electromagnetic focus CRT differentiated
Link Posted: Wed Sep 25, 2013 12:45 am Post subject: |
True indeed
Decibel
Link Posted: Sat Sep 28, 2013 2:28 pm Post subject: |
I'm seeking the components.
I've found 2SA1406 transistors.
But I've no found C3600, there are equivalent?
Can you say the characteristics of the other components?
Link Posted: Sat Sep 28, 2013 5:46 pm Post subject: |
Maybe the 2SA1407/2SC3601 pair would be also suitable for the purpose but they have more parasitic capacitance (which is bad), they seem a bit more widely available (on e-bay at least...)
Find attachments!
2SA1407/2SC3601 datasheet |
Download |
Filename: |
2SA1407.pdf |
112.96 KB |
Downloaded: |
596 Time(s) |
2SA1406/2SC3600 datasheet |
Download |
Filename: |
2SA1406.pdf |
141.27 KB |
Downloaded: |
615 Time(s) |
