Barco Cine9 impressions with internal Moome card
Goto page Previous  1, 2, 3, 4, 5 ... 13, 14, 15  Next
PostLink    Posted: Tue Oct 01, 2013 11:15 pm    Post subject: Reply with quote
stridsvognen wrote:
km987654 wrote:
stridsvognen wrote:
CasetheCorvetteman wrote:
I dont hear the projector ever. Its not loud enough for me to hear it. Even when the fans go fast i cant hear it from my viewing seat.
I cant say ive tried that KM, i run mine straight out of the PC at 817p, although never use it for much yet.
At the moment I am really learning to dislike Moome cards.
Internals are tollerable.
From what i understand the time i have been on this site, Moome converters have been the quality must have for CRT.
Now you guys from down under say its garbadge.. Would be nice to know exact what the problems are, and some alternatives that works better.. ??
Maybe there is a reason that Moome never made a Barco Internal card.? Is it possible that Barco projectors is the problem.?
My comments are in relation to the Moome EXT Fullhd v3 only
The lack of customization available would be a place I would start. These units are built for CRT yet resolutions like 800p or 720p/72 that are commonly used to maximize bandwidth are not supported and there is no pass through that I can see that would allow me to take advantage of what my Lumagen can do.
Dip switch configuration has long since come and gone in almost any technology I have seen yet its still here in the latest generation of Moome.
I will get back to you on image quality as my first impressions may well be influenced by the initial configuration issues I have had so I will let the dust settle and try a few things before comment. I would add that this is not my first Moome Fullhd and I do have a Mux-Hd that works well.
Now i expect that the EXT moom works as the internal, regarding supporting framerates and resolutions.. maybe not when reading the manual, but think Craig once confirmed it did so.
I can put whatever i want into my Moome.. 800 801 802 803.. whatever comes in my mind whatever framerate i desire, as long its inside the bandwidth.
It have a remote to set color space.. video level.. 100 step gamma.. Whats missing.?
The HDfury3 .. with Dip switsch.. so it looks like thats the way to go these days.
If find a moome EXT ill buy it and test it on one of my Marquee..
800p and 720p/72 are not supported in V3 at least check the data sheet and when you try those the Moome will not sync to them. Because someone else uses dip switched doesn't at least to me justify their use.
ifb_fhdv3_v10.pdf
Moome Data Sheet
 Filename:  ifb_fhdv3_v10.pdf
 Filesize:  2 MB
 Downloaded:  75 Time(s)
PostLink    Posted: Tue Oct 01, 2013 11:21 pm    Post subject: Reply with quote
I think the resolutions mentioned are just highlights..
We do all kinds of different timings, and i never seen anyone here complain that the Moome was the problem there.
What happens when you try to run 800P 72hz on yours.?
PostLink    Posted: Tue Oct 01, 2013 11:36 pm    Post subject: Reply with quote
Because someone else uses a Barco CRT doesn't at least to me justify their use.. Wink
PostLink    Posted: Tue Oct 01, 2013 11:40 pm    Post subject: Reply with quote
What are you talking about?
To answer your question with the Moome in the chain it simply flashes on and off. It does this with 720p/72. The datasheet says these resolutions are not supported. For me there should be a pass through option for those that would be using a VP.
PostLink    Posted: Tue Oct 01, 2013 11:42 pm    Post subject: Reply with quote
Are you sure its the moome..? not the projector.?
Do the projector sync to that resolution without the moome.?
PostLink    Posted: Tue Oct 01, 2013 11:44 pm    Post subject: Reply with quote
LOL.. If one day, you get the point let me know.. Wink
PostLink    Posted: Tue Oct 01, 2013 11:45 pm    Post subject: Reply with quote
No Moome all is good either port 3 or 5.
PostLink    Posted: Tue Oct 01, 2013 11:53 pm    Post subject: Reply with quote
im running 720P 72hz now no problem clock 95040000.. any resolution works here.. 720P 96hz.. and 84,3hz.. whatever i can emagine
I think you might have some timing isues.
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40
Correct, works the same in both.
I got it, but i am wondering why a Marquee owner would be saying it?
PostLink    Posted: Tue Oct 01, 2013 11:57 pm    Post subject: Reply with quote
Then i dont think you got it.. look past the projector brand..
mx83toy
PostLink    Posted: Tue Oct 01, 2013 11:58 pm    Post subject: Reply with quote
lol
PostLink    Posted: Wed Oct 02, 2013 12:14 am    Post subject: Reply with quote
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40
I will check and see what the Lumagen is outputting and I will use your suggestion if its different.
PostLink    Posted: Wed Oct 02, 2013 12:20 am    Post subject: Reply with quote
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40
What Lumagen.?
Bedtime up here, let me know if there is any stuff i can test here that might help you..
Ill be back tomorow..
PostLink    Posted: Wed Oct 02, 2013 12:33 am    Post subject: Reply with quote
stridsvognen wrote:
Try these
V total 780
V active 720
V front 5
V sync 5
H total 1694
H active 1280
H front 110
H sync 40
What Lumagen.?
Lumagen Vision HDP Pro.
PostLink    Posted: Wed Oct 02, 2013 5:41 am    Post subject: Reply with quote
Ok, ill get a HDQ here next week i think, so i can give that a shot to.
jbmeyer13
PostLink    Posted: Wed Oct 02, 2013 4:05 pm    Post subject: Reply with quote
I run 1920 x 817p/72 from my HDQ through a Moome; no problems.
PostLink    Posted: Wed Oct 02, 2013 7:37 pm    Post subject: Reply with quote
I run all types of resolutions thru the moome when I was experimenting with blend resolutions, the moome took them all like a good little bitch Wink
Those supported resolutions on the data sheet dos not mean that it only accepts those specific ones, it will support anything up to those. I also noticed it will even go a bit higher. I ran 1080p@96 and it acknowledged that on the marquee's info screen.
PostLink    Posted: Wed Oct 02, 2013 7:44 pm    Post subject: Reply with quote
Oh and I also will add that I have a moome ext HD and it does sync to 800p@72 from my HDQ to my test machine with no issues.
PostLink    Posted: Thu Oct 03, 2013 12:55 am    Post subject: Reply with quote
I continue to maintain that ive never tried it, or would bother since i removed it from service. I will sell it if someone wants it.
Page 4 of 15
