Which is Suitable for me in all 3D products?
espliu
PostLink    Posted: Wed Aug 07, 2013 1:42 am    Post subject: Which is Suitable for me in all 3D products? Reply with quote
I have a 2D projector which is Vivitek H5085,its DLP.My player is oppo bdp-93 that supported 3D movie.
And its HorizontalScan Rate 15, 30 to 90 KHz,Vertical Scan Rate 43 to 85 Hz.
I'm intrest in 3D theatre or 3D theatre plus,which is best for me?
Can any 3D theatre output supported 1080P@24Hz?If not,Why?
espliu
PostLink    Posted: Wed Aug 07, 2013 1:46 am    Post subject: Reply with quote
One more queston:
can 3Dnow 3DN-200 output 1080P@60Hz?
PostLink    Posted: Wed Aug 07, 2013 1:17 pm    Post subject: Reply with quote
Hi!
Your projector will work with both the 3D-Theatre and the 3D-Theatre PLUS.
The 3D-Theatre is limited to 720p@60Hz and 720p@120Hz output.
The 3D-Theatre PLUS can do 1080p@60 as well as higher refresh rates at 720p (72Hz and 96Hz). The higher refresh rates are good for reducing flicker if your projector cannot do 720p@120Hz but may be able to do 720p@72Hz or 720p@96Hz. That said, not everyone is bothered by the subtle flicker (most noticeable on bright scenes).
The 3Dnow 3DN-200 cannot output 1080P@60Hz as it is a 3D-Theatre (same thing).
The 3D-Theatre PLUS gives you more options - it'll let you do full 1080p resolution (but limited to 60Hz). You can always drop down to 720p@120 / 96 / 72Hz.
I found your manual here: http://www.projectorcentral.com/pdf/projector_manual_7136.pdf
It would appear that your projector does not do 720p@120Hz or 720p@96Hz since the vertical scan rate seems limited to 85Hz. These specs are sometimes misleading however as they're quoting typical PC resolutions and refresh rates in the manual. It may actually be able to do 720@120Hz.
I would go with the 3D-Theatre PLUS so that you can do 1080@60Hz and then if you find it flickers to much for your taste you can drop to 720p@72Hz (and possibly 720p@96Hz or 720p@120Hz if your projector allows it).
To order the 3D-Theatre or the 3D-Theatre PLUS at our discounted prices, see here:
http://www.curtpalme.com/Products.shtm#3DConverters
Thanks for the interest!
espliu
PostLink    Posted: Wed Aug 07, 2013 1:36 pm    Post subject: Reply with quote
Why didnot 3D theatre plus output 1080P@24Hz?
PostLink    Posted: Wed Aug 07, 2013 1:39 pm    Post subject: Reply with quote
That would not work for 3D. The refresh rate needs to be at least double of the source (24p in the case of film) in order to show a different image for each eye.
Remember that the 3D-Theatre converter boxes are doing something that is normally done inside a 3D projector.
espliu
PostLink    Posted: Wed Aug 07, 2013 1:46 pm    Post subject: Reply with quote
Oh, I understood.Thanks,Kal.Are you the writer of HCFR manual?
I calibrated my projector with the manual and i1display LT,its perfect!
espliu
PostLink    Posted: Wed Aug 07, 2013 1:56 pm    Post subject: Reply with quote
Can 3D theatre plus output 1080P@120Hz by firmware update?
PostLink    Posted: Wed Aug 07, 2013 1:57 pm    Post subject: Reply with quote
That is me!
I'm glad you enjoyed my Greyscale & Colour Calibration Guide for Dummies!
PostLink    Posted: Wed Aug 07, 2013 1:59 pm    Post subject: Reply with quote
I do not believe so.
espliu
PostLink    Posted: Wed Aug 07, 2013 2:01 pm    Post subject: Reply with quote
Yes,just this article!It help me that had finished the whole calibration.
espliu
PostLink    Posted: Wed Aug 07, 2013 2:22 pm    Post subject: Reply with quote
Kal,why do link to consignia.ca when I click on the "BUY"?
PostLink    Posted: Wed Aug 07, 2013 2:25 pm    Post subject: Reply with quote
They ship for us.
LettyLocke
PostLink    Posted: Wed Aug 21, 2013 7:12 am    Post subject: Reply with quote
Well that was a very good product. I am the person who likes to do some try before buy. I recently hired a Sanyo PLC-XU73 from an audio visual company. I was skeptic at the time of hiring but the end product was very good and I ended up purchasing it. Thinking of upgrading to 3D now with 3D-Theatre PLUS. Seems a very good product but will wait for the final firmware update.
PostLink    Posted: Wed Aug 21, 2013 1:53 pm    Post subject: Reply with quote
What final firmware update are you referring to? The product is out and final. It is not pre-release or beta.
