Will this configuration work?
Bill Roberts
PostLink    Posted: Tue Jul 16, 2013 5:49 am    Post subject: Will this configuration work? Reply with quote
I am considering purchasing the 3D-Theatre PLUS. Does anyone have experience to know if this configuration will work?
PS3 >> Denon AVR-4308CI >> 3D-Theatre PLUS >> Mitsubishi HC7000
I also have
Tivo >> AVR >> VIP >> HC7000 in mind.
PostLink    Posted: Tue Jul 16, 2013 1:41 pm    Post subject: Reply with quote
Hi Bill,
Your Mitsubishi HC7000 has an HDMI input and supports both 720p and 1080p so it'll work. One thing I couldn't confirm is whether you'll be able to run 720p/72Hz or 720p/96Hz. The manual does list some refresh rates up to 85Hz in some of the resolutions it supports from a PC but that doesn't mean it won't work higher/lower. I found the projector manual is here: http://www.projectorcentral.com/pdf/projector_manual_4490.pdf
Some Tivo models support 3D, some do not. So whether you can watch 3D Tivo content depends on your model of Tivo you have. See here: http://support.tivo.com/app/answers/detail/a_id/2424
If interested you may order your 3D-Theatre PLUS here: http://www.curtpalme.com/3DTheatrePlus.shtm
I'd recommend the RF glasses as well if you do not have any.
Free worldwide shipping with tracking is included.
Bill Roberts
PostLink    Posted: Thu Jul 18, 2013 8:04 pm    Post subject: Reply with quote
Going to give it a try. I'll keep the forum posted on my results.
PostLink    Posted: Thu Jul 18, 2013 8:17 pm    Post subject: Reply with quote
Please do Bill! And thank you for your order (just saw it come through) - it's appreciated! This'll ship within 1-3 business days and then typically takes takes 4-6 business days once shipped to any part of the USA. A tracking number will be supplied once it ships.
Jorrel
PostLink    Posted: Fri Aug 02, 2013 8:06 am    Post subject: Reply with quote
Kal I bought the displayer unit 2 years ago, I want to buy the theatre plus unit will the emitter which I have connected on my displayer unit work for this unit.
PostLink    Posted: Fri Aug 02, 2013 1:02 pm    Post subject: Reply with quote
Yes. All of the 3D boxes have the same 3-pin DIN connector for the emitter.
The Theater PLUS is here: http://www.curtpalme.com/3DTheatrePlus.shtm
Bill Roberts
PostLink    Posted: Fri Aug 02, 2013 1:23 pm    Post subject: Reply with quote
I was unable to connect in the recommended order:
because the AVR-4308CI does not support 3D pass-through.
I connected it as:
PS3 >> 3D-Theatre PLUS >> Denon AVR-4308CI >> Mitsubishi HC7000 instead since the AVR-4308CI is the audio controller for the 7.1 speaker system. This means I can't use the TiVo as a 3D input but it doesn't actually provide anything I can't get through the PS3 other than a broadcast antenna connection.
I am getting satisfactory 3D with some minor artifacts using a 3 blue, 1 red setting on the emitter. The projector isn't using the 120 vertical synch rate, so brightness becomes an issue with any higher red settings (they clean up the 3D quite a bit).
All in all, I am satisfied for now, but I see the necessity of 3D pass-through in a couple of years when I was anticipating getting a new receiver.
PostLink    Posted: Fri Aug 02, 2013 1:33 pm    Post subject: Reply with quote
Thanks for the post Bill. If you do want to add more 3D sources, consider using an inexpensive ($20) HDMI 1.4 switcher from Monoprice along with an HDMI splitter to go to the receiver & display.
Jorrel
PostLink    Posted: Sat Aug 03, 2013 2:08 am    Post subject: Reply with quote
Can i buy it from consignia they have a special on the unit....
PostLink    Posted: Sat Aug 03, 2013 2:17 am    Post subject: Reply with quote
Hi Jorrel,
We have the same deal since Consignia actually ships for us. See here: http://www.curtpalme.com/3DTheatrePlus.shtm
We appreciate your support! If you see a better deal, let us know!
Jorrel
PostLink    Posted: Sat Aug 03, 2013 2:34 am    Post subject: Reply with quote
Hi Jorrel,
Hi Kal I just placed my order via Pay Pal...The payment goes to consignia..
PostLink    Posted: Sat Aug 03, 2013 2:41 am    Post subject: Reply with quote
Thank you for your order - it's appreciated! The payment does indeed go to Consignia but we do get a small percentage here at CurtPalme.com at the end of the month at no additional cost to you (we work with them closely). It's what keeps our website running.
Most of our 3D products ship within 1-3 business days. Our free shipping does not include tracking but it usually takes about 10-14 business days on average to reach anywhere in the world.
Cheers!
Jorrel
PostLink    Posted: Fri Aug 23, 2013 7:43 am    Post subject: Reply with quote
Cheers!
Hi Kal,
I got it thanks for your prompt service:
I have question for you in the video chain where would I place the 3d theatre model...
Currently my set up is a PS3 Denon 1.3 receiver connected to my Panasonic plasma screen.
fragzero
PostLink    Posted: Fri Aug 23, 2013 7:51 am    Post subject: Reply with quote
From the specs
INPUT: 1 x HDMI v1.4a (HDCP Compliant)
OUTPUT: 1 x HDMI v1.3 (HDCP Compliant), 3-pin mini-DIN Sync Out (for optional emitter)
Seems the only working spot would be between your source device and reciever.
Source ----- 3D-Theatre ---- reciever
PostLink    Posted: Fri Aug 23, 2013 1:23 pm    Post subject: Reply with quote
+1 to what fragzero wrote. Good luck and enjoy 3D!
Jorrel
PostLink    Posted: Tue Dec 24, 2013 5:37 am    Post subject: Reply with quote
Kal I hooked up my theatre plus everything works fine sound picture all coming through successfully, but the issue I have is that dialogue is very faint and you cant hear it. have you got any suggestions?
I got around it by changing the audio option on the PS3 LCM to bitstream, the sound is no longer 7.1 but DTS 5.1...but atleast the dialogue is clear. I would still like some help on the issue thank you.
PostLink    Posted: Tue Dec 24, 2013 2:30 pm    Post subject: Reply with quote
How do you have everything hooked up from source to display?
Normally you put your 3D-Theatre box right before the display so the sound has already been extracted. Like this:
Source -> HDMI cable -> Receiver or preamp -> HDMI cable -> 3D-Theatre box -> HDMI cable -> Display
If you have the 3D-Theatre before the receiver/preamp, the audio simple simply passes through.
The Theatre Plus supports 7.1 audio. Note that this 7.1 audio support is not important if the signal passes through a receiver first and the video is passed through to the 3D-Theatre PLUS. Itís more about future-proofing. The HDMI signal is not altered/changed in any way (no conversion).
Jorrel
PostLink    Posted: Tue Dec 24, 2013 9:55 pm    Post subject: Reply with quote
I hooked it up this way Source ----- 3D-Theatre ---- reciever
Merry XMAS and happy new year...
PostLink    Posted: Tue Dec 24, 2013 10:09 pm    Post subject: Reply with quote
Try putting the 3D-Theatre after the receiver.
Jorrel
PostLink    Posted: Tue Dec 24, 2013 10:14 pm    Post subject: Reply with quote
OK, I will try it later, do you think it has something to do with the reciever is not a 3d rec.
There is no issue KAL I watched superman in 3d and it looked fantastic all I did to fix the problem is changing the audio single to bitstream...
