CRT to Digital
HK-Steve
PostLink    Posted: Fri May 17, 2013 7:24 am    Post subject: CRT to Digital Reply with quote
Hi Guys,
This is not a typical thread, of CRT to Digital question,
I currently use the Lumagen XS+ with my Marquee, when I go to a Digital, when ever that happens,
Should I keep using the XS+?
I know the XS has a lot of great settings and adjustments, Would this help a Digital projector??
Appreciate your advice
Cheers
PostLink    Posted: Fri May 17, 2013 9:09 am    Post subject: Reply with quote
Yeah keep it.. You will not need the + feature, but all the CMS system in the rediance is worth it. And there is also the scaling if you use it for tv and other SD sources.
You need the 125 point CMS calibration to get close to the performance of your Marquee on most digital projectors.
HK-Steve
PostLink    Posted: Fri May 17, 2013 9:45 am    Post subject: Reply with quote
Cool, Thanks.
Now I just need to save up for ChromaPure..
Cheers
PostLink    Posted: Fri May 17, 2013 1:24 pm    Post subject: Reply with quote
Definitely keep it...
The "+" option will be useless as mentioned above and added ~$400 to the cost of the original unit, but even if you sell it to buy a non "+" version of the Radiance you'll lose more than $400 in the transaction (probably).
PostLink    Posted: Fri May 17, 2013 1:45 pm    Post subject: Reply with quote
yep keep it!!
And the plus option can be used. Cliff used it for the Benq W7000 he had it running at 72Hz
HK-Steve
PostLink    Posted: Fri May 17, 2013 2:14 pm    Post subject: Reply with quote
A digital running at 72Hz, cool.
Can other digitals also do this?
off to do some research.
PostLink    Posted: Fri May 17, 2013 2:29 pm    Post subject: Reply with quote
Of course, in general, there's no point in running 72hz on the digital.
Phoenixed
PostLink    Posted: Sat May 18, 2013 4:55 pm    Post subject: Reply with quote
Specially seeing as the projector does its own handling of the 24hz.
Planar PD-8150/Runco LS-5
PostLink    Posted: Sat May 18, 2013 7:58 pm    Post subject: Reply with quote
That was exactly my point.
PostLink    Posted: Sat May 18, 2013 8:29 pm    Post subject: Reply with quote
but not all refresh rate changes done in digital's is as good as the lumagen. And in some there is no option to do so in the PJ's menu but there is the ability for it if fed that specific refresh rate.
Diddern
PostLink    Posted: Sun Mar 16, 2014 9:14 am    Post subject: Reply with quote
Just for your information I am not shore about the jvc but sony PJ from hw50 and up to vw500 running 72hz and the vw1000 using 96hz this is done in the PJ same as lumagen will do. I would think that the new jvc also uses 72hz.
You can not turn this off in the PJ so using also the lumagen will just be bull.
