Bennyhase
Link Posted: Fri Apr 12, 2013 9:23 am Post subject: Moome ext v3 and 3D - Emitter |
Hello,
because my new 3D-VIP-Theatre will not working i have get a Moome ext v3-Box from somebody here for testing.
Is it possible to connect the Emitter of the 3D-VIP-Theatre directly into the Moome ext v3-Box for driving the Glasses?
Have this emitter and glasses:
http://www.curtpalme.com/RFGlasses.shtm
Needs this emitter a powerstrip via USB ?
And finally: how i have to play 3D-Content from a PC (PowerDVD for Side-by-Side MKVīs ?!?)
Because my 3D-VIP maybe is defective i dont know how i can play a frame-sequ. Videostream for Shutter-Glasses....
Have an ATI-Graphic-Card installed (no 3D capable) with HDMI......
Martin
Rolls-Royce
Link Posted: Fri Apr 12, 2013 3:55 pm Post subject: |
The Moome box doesn't have the VESA connector needed by your glasses' emitter. It has what is essentially a 3.5mm mini jack, so you'd have to use a cable with 3.5mm mini phone plugs at both ends. You will also have to provide power via USB, just as you asked.
I would also strongly suggest you also borrow a 3D Blu-Ray player for the testing. Its output is the standard type 3D signal that the Theater and Moome are looking for. Your posts in the 3D Products area show that you have enough other issues going on without also trying to configure an HTPC to play in 3D for the testing, which can be very involved and frustrating in and of itself.
tanwn
Link Posted: Mon May 13, 2013 6:14 am Post subject: |
I doubt you can connect any bluray player to Moome V3 and get 3D, you need use a pc or radiance to connect to moome, correct me if wrong.
Andrew383
Link Posted: Sun Nov 17, 2013 2:30 am Post subject: |
Do you know anyone who has tried to use a ext full hd v3 with an xbox, on a crt projector? Maybe you.. lol
I have a marquee 8500 ultra. ext full hd v3 moome box. nvidia 3d vision kit with adapter cord for the ir emitter vesa or din
connector to a headphone jack.using vga to bnc for projector to ext v3 then hdmi to hdmi to the xbox ir hooked up via usb
any help would be greatly appreciated.
